XB8 pit tip!!
MI
Anyone having traction problems on bumpy tracks with the XB8 or XB8EC??? Just simply remove the rear chassis brace, this should help the rear wheels stay planted on the ground under hard acceleration. Dont worry about the big jumps, this thing is one tough hombre!!! XRAY ALL THE WAY!!!!!
CA
Not advisable, only if you can get yourself a new chassis after every other race. Use the composite brace in the rear, use 4k or 5k diff oil in the rear, use at least 45 wt. shock oil, rear toe-in at 2 degrees and camber at 3 degrees.
That's my rough/bumpy track set-up...which has yet to fail me
ORIGINAL: SManMTB
I would not run it like that on big jumps. Try a softer rear swaybar instead.
Don't forget with swaybars, that any stiffening decreases grip at that end and increases grip at the OTHER end.
MI
I have yet to bend the chassis even on a bad landing, Ive tried all the things like different shock oil, no swaybar, droop, you name it Ive tried it. The guy at my local hobby shop heard of guys doing this and told me about it, Ive raced almost all summer like this and have had absoultly no problems what so ever. And dont worry ... if I bend the chassis Ive already got another!!! Its only money!
Banned
ORIGINAL: rccheech
I also refer you to my previous post regarding chassis braces.
