RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
gearing question
Old 10-09-2007 | 09:48 AM
Default gearing question
I'm looking for the best combination of gears to really get some good low end punch for a technical track, but some good top speed in the straightaway as well... I have the 13,14,15 clutch bells, and 44,46t for spurs....The buggy is an Xray XB8 with Vspec motor
Old 10-09-2007 | 09:54 AM
SManMTB's Avatar
Default RE: gearing question
13/48 is what you need.
I like the 48 better than a 46. You'll get a lot more useful gearing options with a 48. Anything above 13/46 is just too high unless the track is huge.
Old 10-09-2007 | 11:17 AM
Banned
Using the stock kit spur and clutch bell is the best setup for the track you describe, the trick here is to turn the clutch shoes around for a more positive bite when you hit the gas.
Old 10-09-2007 | 01:43 PM
SManMTB's Avatar
Also play around with different length headers.
Old 10-09-2007 | 01:47 PM
Banned
ORIGINAL: SManMTB
Shorter for torque, longer for top end speed.
Even tyres make a huge difference on acceleration.
Old 10-09-2007 | 01:50 PM
Banned
ORIGINAL: SManMTB
Old 10-09-2007 | 02:34 PM
SManMTB's Avatar
A short header and top end pipe with a super low gearing can be better than a low end pipe with a long header and high gearing for a short track.
The reason? When you move the power band up in rpm the useful rpm range usually also gets a bit wider.
Old 10-09-2007 | 04:00 PM
Banned
Just get a Jammin JP-5 pipe and be done with it.
