HURRICANE XP PRO
I HAVE THIS BUGGY AND I CANT GET IT TO TUNE OUT ANYONE HAVE THIS PROBLEM WITH THESE THINGS I HAVE TRIED EVERY SETTING I COULD IT JUST WONT ACT WRITE WHEN I HIT IT TO GO WIDE OPEN IT BOGGS I HAVE TURNED THE JETS EVERY WHICH WAY BUT STILL NO DIFF CAN ANYONE HELP IT HAS THE SH M28-P3
FL
Go to the redcat support forums and they can help you out on tuning. Best thing to do is set it back to factory settings and go from there.
I DID THAT AND IT STILL WONT RUN WIDE OPEN AL I CAN GET OUT OF IT IS HALF THROTTLE IF I GO WIDE OPEN IT BOGS AND POPS AND STUDDERS ALOT THEN DIES
I WOULD CHECK YOUR CANOOTER VALVE THEN I WOULD CHECK YOUR MUFFLER BEARINGS. This forum so desperately needs a caps lock filter.. reading people who post in caps makes my brain hurt.
You most probably have one of the following problems.
1) an air leak in your cases - take it apart and re seal everything.
2) an air leak in you carb - Check carb seating and O-ring and needle valve seals.
3) leak through you bearings - Replace bearings
4) your cylinder liner/ piston is shagged - replace (or just buy a new engine)
Do everything in that order with the cheapest being first and it might not cost too much
