LEAKING DIFFS
LEAKING DIFFS
Has any got the same problem with the hyper 8.5 pro diffs i cant seem to stop the 6 screws that attaches the flywheel to the diff from leaking any answers would be great cheers
Banned
RE: LEAKING DIFFS
6 screws, leads me to think you have the spider diff in there, if so ignore the last 2 posts as they are irrelevant, SPIDERS HAVE O-RINGS, Dab the head of each screw into some RTV (silicone) sealant before you slot it in, then do each screw up in the diametrically oppossed style, sit the diff on one end so that the heads are at the top and allow it to dry.
FL
RE: LEAKING DIFFS
gas·ket (gÄs'kÄ*t) Pronunciation Key
n.
Any of a wide variety of seals or packings used between matched machine parts or around pipe joints to prevent the escape of a gas or fluid.
n.
Banned
RE: LEAKING DIFFS
Seal (se-al) n.
An item used to prevent leakage.
A mammal found predominantly in cold waters.
When using terminology it's better to know what your talking about than to give advice on the wrong type of diff.
FL
RE: LEAKING DIFFS
Never said paper or rubber just said gasket, and if you have better advise learn to give it in a way that does not insult others trying to do the same. This site is not about superiority, but commrodery.
IA
RE: LEAKING DIFFS
ORIGINAL: hrdcoreglf
