RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
Temps
Old 01-19-2008 | 06:02 AM
Osirisf16's Avatar
Default Temps
I have another silly question for you. I wonder something. Now that is winter the engine temps are hard to reach at the top (120 celcious). I have a friend that run his car and the engine's temp is 80-90 celcious. Is that bad? I mean, in low temps, the engine wears, right? What temps must an engine attampt to be ok?
Old 01-19-2008 | 07:22 AM
Default RE: Temps
Mine gets pretty hot, just lean it out more mate.
Old 01-19-2008 | 08:12 AM
digifox's Avatar
Default RE: Temps
No DO NOT LEAN IT OUT (as you lean it out less fuel is going to the engine therefor less oil is going to it)
All you need to do is put a sock on the head to keep heat in it like so
Also let it warm up to about 82C before taking off
and before you start it warm the engine up(without it running) to at least 43C
Then just tune it to where it runs best, if it starts getting a little warm pull the sock down a bit.
And the least you`ll want you engine running at is 104C
