BEST PIPE FOR A MAMBA .21???
That's it...my new Axe Rossi mamba .21 Competition has arrived (i read the instructios and the break in takes ages...3 - 4 tanks running on the ground, and 1 or 1 1/2 gallons running half throttle and rich!!!!) for my Hyper 7 TQ PRO....until now the engine promises a lot, but i'm thinking in changing the 13T chutch to a 14T
I'm using the Hyper pipe, i have read that some people use EFRA, JP 3, Hong Nor 2050, etc...Which should i use bought??
I use the buggy 50% bashing and 50% racing
i have search them on ebay, and they cost almost the same, so making a filter by price can't be done
Thank's in advance!!!!
GA
RE: BEST PIPE FOR A MAMBA .21???
a jp3 pipe works well with the engine, the engine needs to be heated up before you start running in the engine it is very tight.
Thank's...yes i'm using a heat gun, but i'm wonderig....the piston never get stuck in the upper point (cold or hot), i have never feel it so tight....and it starts with no problems, after a liter or 1/4 gallon, i don't need to heat it anymore...is this normal??? (i've had read a diferent story)
I'm asking these because i had have some engines (like the hyper .21 8 port race), that are really tight, even after a gallon they still need to get heated, or get the piston realased with a scre driver turning the flywheel...
The other question...today i've notice that the back of the engine is full of nitro (and the baterry, the receiver box, etc), could be the reason of these that i'm using the pipe without it's support (i know i've should use it, but i'm searching it now)
Thank's
Thank's
GA
i know the mamba i broke in was pretty tight well after a galoon put ever motor is different, and you should of some gas in the crank case from being rich from breaking it in, if it is blowind fuel from around back of the exhaust port your seal my be bad.
My friend runs the mamba his break in was a nightmere was forever locking as was so tight, loosened nicely buy 10 tanks and he runs the jp3 and loves it.
ORIGINAL: adz06
Check out the mamba thread, I think its in the buggy section, might be truggy section. Long story short, its a great engine. JP-3 works well on this engine. A 2013 pipe does too, wakes up the top without hurting the low end.
I'll see if I can find the thread and link it, lots of info.
