1/8 buggy wheels
WI
Are all 1/8 buggy wheels the same size? I am refering to the nut that fits into the back of the rim. I am still sort of new to this and forgive me if this is a noobish question. I am looking at tires on ebay and a lot of them just say tires for a 1/8 buggy with no specific size listed.
Nate
Nate
Banned
CA
ORIGINAL: nr7286
Nate
Nate
FL
Yes, they will fit most 1/8 scale buggies. You have to be careful though. I run a couple of Jammin X-CR's and found that proline and some other style rims have a slightly smaller inner diameter. This causes the rim to rub on the ends of my tierods, so I have to use the ofna/jammin rims.
What he said^^. You should be fine using any 1/8 wheel unless you own an Ofna.. Pro-line wheels seem to rub a little but panther wheels work fine (repeat of what hrdcoreglf had said).
A buggy wheel with a smaller inner diameter? Does that mean they are cone shaped?
Or is offset? Whilst on the topic of wheels, do they come with different offsets?
