RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
what diff oil in hyper7 ??
Old 09-29-2008 | 05:20 PM
Default what diff oil in hyper7 ??
Hi, well I recently got a hyper7 and am wondering what diff oil I should put in the front center and rear diffs? I understand that will depend on the track I use it at so here is my question, how do different weight oils affect my buggies handling? I've heard a good setup is 4000 in the front, 10000 in the center, and 1000 in the back, could someone please explain what these different weights do and what more in the front versus the back means? What about the center diff? How does that affect handling?thanks guys
Old 09-29-2008 | 05:31 PM
Default RE: what diff oil in hyper7 ??
7wt,5wt,2wt in the order
Old 09-29-2008 | 08:25 PM
MX250's Avatar
I run the same setup on my H7 and it handles great....
Old 09-30-2008 | 10:25 AM
Ok sounds good but could you please explain how to remove the diffs and how I change the oil in them?
What about my other questions? How does thicker oil affect handling in each of the diffs? What's the rule of thumb? Thicker oil for looser surfaces? Please give me an example of a setup for both sand and asphalt which are basically opposites as far is traction and handling is concerned, I want to know this to be able to understand and tweak my own setup.
Old 10-18-2008 | 07:09 PM
Hi again guys, could I use 10.000 in the center diff rather than 5000?? What are the advantages of using 5000 over 10.000? I thought 10.000 in the center would be better for braking and accelerating, right?
7000 in the front and 2000 in the back sounds good.
What are the stock oils? Thanks
Old 10-18-2008 | 07:54 PM
46u's Avatar
46u
There are many variables to this question about what oil to run but in my experience 10K is way to heavy. Depending what track I run at I run 5K,5k,2k or 5K,7K,2k and some times 7k,7k,2k and this is subject to change for track conditions. I do not even have any 10K. Do you understand how a diff works and the purpose of having them? The thicker the oil the less limited slip you have.
Old 10-18-2008 | 08:22 PM
Ok cool will probably go with 5000 7000 and 2000. Yeah I know more or less how diffs work, thanks for the helo man I appreciate it!
Old 10-18-2008 | 08:27 PM
46u's Avatar
46u
Like I said see what others at the track are running for a place to start. Good luck and have fun.
Old 10-19-2008 | 06:24 AM
Oh one more thing, exactly how much should I fill the diffs with oil? I had read 80%... is that ok? or should I fill it up 100%?
Old 10-19-2008 | 11:55 AM
46u's Avatar
46u
Do not feel them 100% or they will end up leaking. I fill mind up to about 80% then spin them trying to get all the air out. I let them sit for about an hour and top them up to a little over the cross pins.
Old 10-19-2008 | 05:31 PM
Ok thanks!!
Old 07-04-2009 | 10:51 AM
Am I going to FAST, 7000 front 50.000 centre and 3000 rear.
Old 07-04-2009 | 12:13 PM
Chris_RC's Avatar
ORIGINAL: lez1troubles
Thats alot of acceleration. I hope you are just bashing around. Is that like a locked diff?
Old 07-04-2009 | 01:24 PM
High speed bungie jump
Old 07-04-2009 | 04:14 PM
I run my hyper 7 at 5k 5k 2k
Old 07-04-2009 | 08:52 PM
ace9213's Avatar
i run at 5k 7k 3k. i dont know much about diffs. does a lighter oil mean more slipp? and what does more slipp in the diff do to the car? thank you
Old 07-05-2009 | 12:16 AM
Chris_RC's Avatar
Google Xray buggy and truggy setup guide and go to diffs, that will tell you exactly what diffs do and how they effect handling.
Old 07-05-2009 | 02:21 PM
ace9213's Avatar
Thanks Chris
Old 07-07-2009 | 03:28 PM
It depends upon which kind of center diff you have. If it is a spider diff, I would run 5, 5, 2 or 5, 5, 3. If it is a standard diff, then go with 5, 7, 2-3. If it is a torsen then 5 in front, 2-3 in the rear and leave the center alone.
