difference between mr&jx ninja
Unfortunately, they are not interchangeable since they are made by different manufacturers. I do know that parts are interchangeable between the MR Ninja and the new GRP motors. I do not know the specifics as to what is all interchangeable though. I'm sure the piston/sleeve is though. I drove a truggy with the MR .28 in it. Very fun to drive. Probably too much power, but that thing had torque for days and great top end.
MN
Yes all the GRP parts are interchangable with the MR Ninja engines. As for the JX engines, The case is the same as the XZ engine, the piston / sleeve / rod the same as the OS Speed V Spec, and the crank is from the Speed Spec minus the tungsten weights.
