Your opinion on (servo support tray for Losi 8ight) please!
http://www.amainhobbies.com/product_...ducts_id/11668
Is this worth purchasing? Not new to rc but this is my first buggy. I am trying to prep as much as I can. I have a couple months here in Canada before my first racing season will start. I know there are issues with not properly setting up throttle servos with the losi 8ight 1.0. I will try my best to set up properly with the added instructions but, without purchasing the 2.0 servo tray and linkage will this help the longevity of the t/b servo? Just curious. I have to make an order at amain soon and if so, it can't hurt to throw this in as well. Pros and cons? Thanks. Ken
TN
RE: Your opinion on (servo support tray for Losi 8ight) please!
Just get the new updated servo tray from Losi.
Apparently it's updated and the servo issue has been addressed. They moved the Throttle servo out a bit more and gave it more support.
OH, btw.. i noticed you mentioned a linkage in that post..
is there a difference between the linkage length on the 2.0 rather than the 1.0? Cause I JUST ordered the 2.0 tray about 2 days ago and didn't think of getting a new linkage. LOL
From what I have read you need the 2.0 linkage to go with the 2.0 tray. This is the reason I want to find out about the servo support try for the 1.0. It is cheaper than buying the 2.0 upgrade.
I have that CF tray and I took it off. It raised the servo up to where the linkage rubbed the body. I've been running the 1.0 tray with no stiffener for 2 seasons with only two failures; both of which were my fault. Those stiffeners are bogus as far as I can tell, but I'm sure others will argue differently. I should mention that I leave out the screw that holds down the battery box. That way, when the chassis flexes, the tray moves more freely.
If it were me, I'd spend the extra coin on the 2.0 tray and linkage.
MB, CANADA
you dont need the linkages...its tight but can be done with the stockers by cutting down the fuel tubing length....also the dirt guard will need to be modded as well as you might need to add a shim under the throttle servo or dremel the chassy 1-2mm...as the 2.0 is a TFT therefor its been milled and some servo's will bottom out on the chassy....but overall dont waste your time with the 1.0 tray...get the 2.0 and be done with it....ALSO get the 2.0 steering plastics....to you have a servo saver that actually works like they are designed to.
(!!!!!!Is there really an issue if your servos is set properly?!!!!!!) Integra, whats your opinion on this question. Thanks. Ken
PA
The only problem I have heard about the graphite parts are they get very brittle when its cold outside. So if you dont run in cold weather you should be fine.
MB, CANADA
ORIGINAL: nissan300ztt
you Officially DONT HAVE A CLUE.
Kman...TFT refer's to the newer chassy the Tuned Flex Technology chassy....and yes the old tray did have issues with both throttle and steering.
PA
I had graphite parts on some of my other RCs planes, revos, savages, most of my truggies..And if it gets cold outside like below 35 those parts get very cold and brittle. Ive seen graphite parts snap. So dude learn about graphite and what happens when it gets cold. Then come talk to me.
MB, CANADA
Your officially a retard.
PA
And im sure you have access to aerospace grade carbon fibre. And also graphite and carbon fiber are based on the same material but not the same thing.
MB, CANADA
once again...preaching to the Wrong crowd.
http://s150.photobucket.com/albums/s...arbon%20Parts/
PA
Dont get me wrong thats great work you do. But I still stay carbon fiber in the sense that im thinking is completely different. It looks like the components your making there are graphite. Yes same material as carbon fiber. But I have a carbon fiber hood on my Z car looks much different then the material youre working with their. Ive never had luck with "graphite" parts. So therefore I use titanium or aluminum
I can't believe this has turned into an argument about who knows more about CF.
It's not a question of whether the servo plate is durable, it's whether it even serves a purpose in this application (preventing servo blowouts). And THAT is another arguement in and of itself.
MB, CANADA
No comment....You wanna get Schooled in Carbon...drop me a PM.....im done with you.
PA
PUNK***** id school you, most of the parts on my Z are carbon fiber. Stop being a DOOSH (mis-spelled on purpose) and get a life LOSER.
wow those are some sweet carbon fiber parts you made integra. I have only had one servo failure, but that was because I didn't set it right. I want to be on the safe side and not destroy any more servos, so I ordered one of these but I have yet to test it.
Ohh man, can you feel the maturity in here.
Original poster - I've ran a losi 8ight 1.0 pro kit now, completely stock, for nearly a year, and with the o rings undernead the battery box (the orriginal addendum) i have never burned out a single servo in it!
I run ace ds1015's for what its worth!
ORIGINAL: K_B
Oh and to get back on topic I agree with integra and just get the 2.0 tray. I have had my 8ight for two years and have only burned one throttle servo....and that was my fault.
I guess some comments have been erased? Any other input would be appreciated. From what I have heard the 2.0 tray can be made to work without the 2.0 linkage. Has anyone done this? And what about the tray support? Lets be nice!
MB, CANADA
ORIGINAL: kman43
No support needed for the 2.0 tray...but pending on the servo...you might need to dremel the chassy a hair or raise the servo up with shims.
TN
ok, well I installed my 2.0 tray last night. I used the 1.0 linkage, and didn't change anything except cutting a bit of fuel tubing from the brake assemblies. The tray works good, and everything goes smooth.
The Throttle servo is raised on the 2.0 tray and has a LOT of reinforcement. I couldn't get my servo bolted down with the grommets on and the stock screws.
good stuff.
good stuff.
MB, CANADA
ORIGINAL: A.B.U
good stuff.
good stuff.
that's normal...even on the 1.0 with some servo rubber grommets the screw's would barely have 2-3 threads in the plastic...so i used the next up longer 4-40.
