Shock Springs Sizes/Manufactures
Is there a range in size that is acceptable when replacing the shock springs on the Losi 8 rtr buggy? For example if the current springs that I have are 15mm can I replace those with a 16mm or a 14mm spring from a different manufacture other than losi. The link shows what I want to replace the exsisting springs with.
Will most truggy springs fit a buggy?
http://www.amainhobbies.com/product_...ducts_id/16939
