Losi 8ight 1.0 Setup
CA
I have the losi 8ight rtr with jp-3 pipe, airtronivs 94357 for throttle, and futaba s9351 for steering. I recently went to my local track, Thunder Alley, and I noticed the rear end was really loose. I was running Panther Komodo Dragon 2s (they look alot like crimefighers) with hard foams, so I thought that could be partly the problem, but I dont want to get a new set of tires now. What I am looking for is stability and rear traction. I was thinking putting more rear toe in on it (if so where can I buy it?). But is there any other things that you would suggest to calm the rear down and make it easier to drive? Also, I noticed that my fronts wore alot faster than rears. Why is this and can I switch fronts for rears when the fronts get more worn to equalize tire wear? thanks!
RE: Losi 8ight 1.0 Setup
If the tires are the culprit, try different tires. Tires are 75% of the battle with setups usually. To calm down the rear end, many people swap in a 3/3 anti-squat/toe plate in the rear:
http://www.carolinasrc.com/Webstore/...idproduct=2684
There are different ones from different manufacturers including adjustable toe plates too.
Have you tried any of the setups on Losi's site:
http://www.losi.com/Products/Support...rodID=LOSK0800
Front tires are wearing fast than the rear because weight shifts to the rear allowing the fronts to spin. You can swap them if you so choose. If you want them to wear more evenly, use thicker oil in the center diff to distribute power to the front/rear more evenly.
CA
I am running the Drake neo06 setup. On their site it says: Adam Drake's Setup from the UK Neo-Buggy Race
It is at 5/7/2 now. Someone who was helping me said it felt foreign to his brothers Losi 8ight rtr and to run 5-5-3 in the diffs. he said his brother ran my same setup and that is what he cahnged and it should help it alot. What would that diff setup do? he also said to move the shocks to 3 on the tower. The Losi manual isnt that good for explaining setups..... []
So if I would change the diff oil from 7 to 5, my fronts will wear extremely fast, but tyhen what will it do with stability/traction? Same about 2 to 3 in rear diffs.
THANKS!!!
THANKS!!!
Here's a link to the X-ray Setup Book in PDF format. It should help.
http://www.teamxray.com/teamxray/sho...p?file_id=4461
I'm no expert with setups either. I just know the very basics. If you run thinner oil in the center diff, you put more power to the front wheels. This means that the front is doing more work to move the car and will pull it through the corners a little quicker and turn sharper since the rear wheels won't be pushing as much. With only 2K in the rear (which is what I run too), you get more diff action and allows sharper turning as well. But it also makes it a little less stable when exiting a corner from what I've experienced.
I'm a friggin' Saint!
I think it has something to do with the fact that you seem to be getting into territory where there is no real easy answer. So people either don't know how to answer, or don't/can't take the time to answer. Plus, the traffic on this forum is down a bit maybe due to the off-season.
MI
I'll share our winter storm warning with you. The AK cold finally got to us in MI. I run the 3 toe/3 squat in my rtr and it held the rear pretty good. I think it drives more stable at higher speeds, and rotates around the corner better. Not sure if this is part of it but it get's bouncy in the rear more when the track gets blown out with the squat in there. Going up 5 in shock weight usally takes care of that. I only found the dragon 2's to work good in a clay/ sand (heavier, loose) surface. I tried them on hard clay and it was like glass. hope that kinda helps.
MI
ORIGINAL: Chris_RC
There is no off-season in socal! I think it hit the 80s today!!
