help with rebuilding my diff
ok im trying to rebuild my diff(i striped out my diff ring & pinion gear) thing is i cant figure out what the lube is called on the ring and pinion and cant figure out if i use a different lube on the inside of the diff and what weight for the frount rear and middle diff. if someone could point me in the right direction it would be helpful.
