Bevel gears design?
Bevel gears design?
Hey guys,
I was looking the MP9 bevel gear design and it's pretty much the same design (stright teeths) as my old MP-5, the Mugen MBX6 however are helicoildal (sp?) design, wich me thinks is better for smootheness and overall work but I coul dbe wrong. Any advenatge or cons of each systems?
MP9
Mugen MBX6
MP9
Mugen MBX6
IA
RE: Bevel gears design?
My guess is that they order them in by the hundreds and are still using them??? The price that they can command justifies the extra expense that it would be.
IL
Well I haven't had any problems with the "standard" bevel cut gears, although I did use both. The difference I feel is that the spiral cut gears are smoother, but require more maintenance to shim the diff appropriately. It needs to be spot on for the best performance. The standard cut gears aren't quite as smooth, but they feel more durable and raw, if you know what I mean.
IL
I know that truggies use the spiral cut gears so that they can use a smaller spur gear. It's why older truggies like the Jammin CRT used huge spur gears in the past. I guess the spiral gears allow a more extreme gearing in the diffs than the standard gears. However, spiral gears in a buggy don't seem necessary for gear ratios.
FL
mugen and ae have spirals in their buggies, it allows for a constant state of mesh, when one tooth exits there is one hole tooth meshed and another beggining. only problem i see is shimming accurately is crucial, also bearing play needs to be checked for regularly. if the bulkhead or diff bearings get wobbly there will be too much play in the mesh.
Hi, I have the Kyosho MP7.5 and it came with the same ones as the MP9, I changed them out for the ones from the MP7.5 US Sport's, NO problemo. Seems to be stronger but you have to shim them good or they just eat themselves up. Once they have been set up they work good;-)
I think the number are: Drive bevel gear(13tooth)IF21 and the bevel gear set for (MAD Force)MAO50. They fit eazy.
