RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
Kyosho
Old 08-01-2009 | 02:39 AM
Default Kyosho
I have a Kyosho Inferno 7.5 sport When its up to running temp it stalls and hard to start again.Can anyone help??GX211 motor!!
Old 08-01-2009 | 09:05 AM
Osirisf16's Avatar
Default RE: Kyosho
Give more info please. What do you mean when it get it's temp? How hard to start again? Is the flywheel spinning easier than when it's cold?
Old 08-01-2009 | 09:15 AM
The_Collector's Avatar
Default RE: Kyosho
Find out why it's stalling. For hard starting, the first thing to check is the carb. Some of these carbs. developed bad o-rings that tend to leak and let air in (and fuel out!). If it's going lean as the engine is heating up and stalls, the fuel will have a hard time getting to the carb until the engine is cooled down again. Kyosho sells the repair kit that has the o-rings for the main needle and low speed adjustment.
Also, bad fuel lines with even just a pinhole will cause these problems.
