RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
WHEELS ANGELS FOR GRIP
Old 08-12-2009 | 01:57 PM
Default WHEELS ANGELS FOR GRIP
<span style="font-size: larger; ">Anyone know the best angle for rear and front wheels for better grip?I will be thankfull for any answers</span>
Old 08-12-2009 | 02:47 PM
46u's Avatar
46u
Default RE: WHEELS ANGELS FOR GRIP
Caster or camber or both?
Camber is best set so the tires' contact patch is as big as possible at all times. So with a stiff suspension you'll need less camber than with a soft one.
If the tires wear evenly across their contact patches, camber is about right.
On really bumpy tracks, adding a little more negative camber (2 to 3 degrees) can help traction and reduce the chances of catching a rut and flipping over.
More More caster aids stability, and handling in bumpy sections.
Less Less caster increases steering drastically.
Steering feels much more direct, the car turns tighter and faster.
Here is a very good site on handling.
http://home.scarlet.be/~be067749/58/
Old 08-12-2009 | 03:13 PM
Thanks a lot ..That site was really helpful
