Is it normal?
I got a question I just wanted to know if it normal for a front and rear diff to get hot will the car is idling? I am doing my brake in on my Rc engine, I stopped the engine after running a tank at idle and picked it up from the back of the car with my hand under the rear diff to realise that is it extremely hot, under the front diff was not as hot as the rear one. Is this normal?
Pyro
Pyro
FL
Is the car off the ground. Its best to let it idle, with tires on the ground. Check the idle it might be too high. You don't want the engine to be spinning the tires with no load on them.
FL
Your diffs can get hot if they are not greased. A lot of friction between crown gear and pinion gear. Also if you have stock diffs they could be filled with grease and not fluid which has broken down through use and need to be relubed or poss rebuilt.
If you are performing your break in, you are not running the car down the road @ high speeds. The motor is still at the factory settings witch will be really fat, so fat to the fact that you should have to empty out the tunepipe before you can start it to evac the excess oil. So have you leaned the air out yet ? What step of your break in did you notice your diffs being hot?
My money is on the motor warming everything up, unless you put the vehicle on a brick which will decompress you suspention and put the shafts at an angle which may cause a lil heat but not much. Do you Have greased difs or oil sometimes grease in front and oil in the center and rear. Do you have aluminum dif cases or plastic.
Give us just a lil more info.
AL
do any one know any thing about the Tornado S30 rtr buggy is it a good buggy . i seen it on this site[link=http://www.redcatracing.com]red cat site[/link]
CA
ORIGINAL: jermainezey
The dif oil metled thermal set plastic ?? UM Wow
ORIGINAL: redlined_b16a
I heard of people burning the fluid in the diffs under extreme racing,oil in the diff getting really hot and melting the plastic case
AL
