Air pressure
Air pressure
I'm having a problem with my guggy(Storm evo rtr) . its been 3 months since i last raced it, and now that i have tried to use it again i;m having a problem starting it..Specificly, as much as i try it wont suck fuel from the tank and into the engine(no fuel running through the fuel line)..When i tried to insert fuel directly to the air valve ,it started but it was a matter of seconds before itn shu down,it also didnt respond when i tried to give some throttle..i will apprishiate anyt kind of help
RE: Air pressure
Check your needles are clean on the carby, in particular the main needle. If you leave fuel sitting around for too long it turns to jelly and gums up everything. If this has happened its probably the same inside the engine all gummed up and possible rusty.
OK
RE: Air pressure
First of all open up the engine clean up all the gunk, take a clean fuel line and connect it to the fuel intake and blow from the other end to get all the gunk trapped inside the carb. Same thing with the fuel tank. Before sealing the engine make sure to lube it with some after run oil.
