hyper .21 starting problems
I jsut replaced my pull starter, with the back [plate from ofna so i can ise a drill, tried to start the buggy and it just keep cranking seems kike the one way bearing is good glow plug is good and so is the fuel not real familiar with these motors and I haven't started since oct. i did use after run oil when i put it away for the winter.
NY
RE: hyper .21 starting problems
you have to check the presure pin and spring it sticks out of the bottom of the connecting rod and engages the starting shaft its only about 3.00 bucks but it deffinitly will look likr a bad one way
What did you use to convert to rotostart? I"m looking at a hyper 7 Black that comes with the hyper .21 motor and was wanting to order the backplate to go to rotostart when I buy it. A link would be greatly appreciated.
