RCU Forums
-   RC 1/8th Scale Buggies (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/)
-   -   duratrax axis help (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/1442811-duratrax-axis-help.html)
tomas13 01-18-2004 07:16 PM
duratrax axis help
how do you remove the spur gear??? aim me at slushsysteeler234 or email at [email protected]
polstery 01-18-2004 07:27 PM
RE: duratrax axis help
Post Deleted by Moderator.
tomas13 01-18-2004 08:13 PM
i need help not smart ass coments
dagass 01-18-2004 08:25 PM
It should be fairly simple. Pull the center diff out of the buggy and remove the screws that hold the spur gear to the diff case.
Mugen Mbx5 01-19-2004 10:49 AM
I think you have to open the diff up on the axis,but can't remember for sure.
Sherak 01-19-2004 11:11 AM
Here is the blow out, it shows it in good detail [link=http://www.duratrax.com/pdf/dtxc0070-exploded.pdf]Axis-Blowout-link[/link] did you not get this with the car? I must admit it was difficult to find, having to to type "Duratrax Axis manual" into Google was a real struggle ;) :D
tomas13 01-19-2004 03:33 PM
thanks but now it looks like the person who owned it before stripped the screw any tips on getting ou a striped allen wrench screw
dagass 01-19-2004 03:34 PM
IF you have a dremel tool, use a cutting disk to slot the head and then use a flathead screwdriver.
tomas13 01-19-2004 08:52 PM
its a set screw you cant reach it
Sherak 01-20-2004 04:13 AM
You'll have drill a small hole in the head and use a screw extractor [link=http://www.arizonatools.com/catalog/browse/3012-3009/]Link_to_screw_extractors[/link] they are not cheap but they are very handy. (that said you may be able to pick up individual ones instead of a set from your local tool merchants).
