RCU Forums
-   RC 1/8th Scale Buggies (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/)
-   -   The dumbest Question ever (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/2269988-dumbest-question-ever.html)
Harb 10-19-2004 09:48 PM
Hi guys and gals,
This is my first post on the forum, so thanks for any help you can give me here.
My wife and I have just become the proud parents of 2 shiny new nitro buggies.
My question is, How do we clean them after a hard day out in the dirt??
There seems to be grit in everything. I have used an air compressor to blow most of the muck away, but there is still heaps of dirt and grit everywhere............
sorry if this is a really dumb question, but I guess if you don't ask I may be overlooking the obvious.
cheers
John[8D]
zzman 10-19-2004 09:53 PM
RE: The dumbest Question ever
i blow mine off and if that dont get it use some carb cleaner and then blow it off and some guys use wd40 and then blow it off after all that. but using a air compresser usually gets most of it off. there is a tread on this a few pages down.
Harb 10-19-2004 09:58 PM
geez that was fast!!!
Thanks;)
El Pirata 10-19-2004 09:59 PM
If I clean my stuff it had better fome off with an aircompressor and a paint brush
Carnutz68 10-19-2004 10:52 PM
You can remove your wheels and clean them with water if need be
dont use water near electronics or you might have to replace them
oil any bearings that get cleaned also:D
Welcome to the world of RC
Jonnyd 10-19-2004 11:35 PM
I would only use water on the wheels if i know they are sealed but otherwise i wouldnt because water will get inside the tires and make the wheels unbalanced.
zzman 10-20-2004 05:08 AM
also water can get in the wheel bearings and mess them up. its just not a good idea to use water unless it is just a damp rag...:D
Model Mania 10-20-2004 08:44 AM
Does ur wife not know how to pack the dishwasher, a couple of plates there a couple of buggy's here etc. LOL.[sm=lol.gif]
MassiveMods 10-20-2004 09:34 AM
way i clean is this..
Brush off all major stuff... with a brush
Blow off with compressor
take out servos
Coat car with oven cleaner
Sit for 20 to 30
Go over with tooth brush and bottle brush and Jif
Rince under hot water
Blow off with Compressor
Dry with towel
Sit infront of heater till completely dry
Completely spray car with electrical silicone spray
Wipe off excess
Voila should take about an hour
Little trick, put a bead of silicone sealant around the little socket that you attach the horn to, let it dry and put the servo horn back on, will stop about %50 of dust and some moisture getting in..
Harb 10-20-2004 10:04 AM
Thanks everyone for your replies...
We don't have a dishwasher anymore........ we sold it to buy the Cars Hi Hi....
The lawnmower is gone also, and the weedtrimmer has found its new home in a nice little enforcer hull..!!
We recon R/C is much more fun than the drab daily chores around the house..;)
Thanks again everyone
John
scale only 4 me 10-20-2004 10:13 AM
1 Attachment(s)
How I do it,,,
Remove body and wheels
Clean them with "simple green" and water, hold the wheels face up making sure you done get water entering the wheel vent holes. Soak down with the simple green, let sit a few minutes to soak in and then rinse with warm water, set aside or dry with a towel.
Chassis,
I use a air compressor, denatured alcohol and one of these siphoning spray guns, It acts like a mini pressure washer, then make sure to blow the car dry as much as possible and your looking good.
djray77 10-21-2004 01:33 PM
OK all these tips are using a air compressor, What if you dont have one?
oldchopdoc 10-21-2004 01:42 PM
Hold it out the window and drive really fast down the road!:D
djray77 10-21-2004 01:47 PM
ROFL!!
oldchopdoc 10-21-2004 02:04 PM
Honestly, you could try nitro-bast. It's an aerosol cleaner sold at most hobby shops.
djray77 10-21-2004 02:13 PM
OK I know what your talking about compressed air in a can.
zzman 10-21-2004 02:19 PM
ORIGINAL: oldchopdoc
Now thats funny ***** ! i couldnt stop laughing at that crack:)
djray77 10-21-2004 02:21 PM
Yeah that was a good one.
