Some questions
Im not gonna get into 1/8 scale buggies or even nitro for a while as I race electric and even if I did it would be for fun rather than races and competing. If you wouldn't nind could you please answer a few questions so I can clear up any problems I see in ever having a Nitro and ood points.
1. If a nitro engine for some reason keeps spinning, how do you stop it as it aint like electric where you unplug the battery, or is it? 2. How fast would a Dyratrax evader bx nitro rtr or the Hot Bodies Lightning RR rtr go in mph, as these are 2 of the cheapest and would be my most liely to look at. 3. Can you run nitro in wet grass, mud and rain 4. What are the mains problems with nitro engines and cars Thank you |
RE: Some questions
Q1..........you squeeze the fuel line or stick your foot over the exhaust to stop it
Q2..........most stock RTR's go about 30-40mph but a lot depends on fuel and gearing etc Q3..........Yes..........just need to make or buy an airfilter cover to stop water getting in Q4..........They can be a PITA to start with a pull start and need a little TLC to keep them upto top performance Hope this helps |
RE: Some questions
Thanks richie and what A coincedence you live in cleveland, wherabouts, i live ins tockton, about 5 mins from middlesbrough, where do you live just out of interest
RE: Some questions
Sent you a PM
RE: Some questions
ORIGINAL: Richie-EB4 Q1..........you squeeze the fuel line or stick your foot over the exhaust to stop it Q2..........most stock RTR's go about 30-40mph but a lot depends on fuel and gearing etc Q3..........Yes..........just need to make or buy an airfilter cover to stop water getting in Q4..........They can be a PITA to start with a pull start and need a little TLC to keep them upto top performance Hope this helps |
RE: Some questions
stopping it by plugging the exhaust can actually flood the engine at the same time, the best way is to just pinch the fuel line
