RCU Forums
-   RC 1/8th Scale Buggies (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/)
-   -   SO WHAT'S THE DIFFERENCE? (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/2886497-so-whats-difference.html)
MBX5T Maniac 04-17-2005 09:40 PM
what's the difference between the ofna hyper 7 pcr and the ofna hyper 7 pbs?
is one more raceworthy?
which one is tougher?
and tell me what other differences there are
edit: Used " in title, not '
Dealspeed 04-17-2005 09:47 PM
RE: SO WHAT"S THE DIFFERENCE?
There indentical except one thing, the PCR has a laydown servo tray and the PBS dosnt.
The lay down trays is supposed to lower the CG.
I have the PCR and i honestly couldnts say if it matters much, most likely not
Oh yea the stock bodys are alittle different
MBX5T Maniac 04-17-2005 11:17 PM
okay, i knew that, but what makes it 30 dollars more on tower?
Foxy 04-18-2005 04:31 AM
ORIGINAL: rustler08
The lay down servo positioning and the 'PCR' (Paul Coleman Racing) branding. Nothing else.
I know someone with a PCR (Chris), who now wishes he had the PBS due to servo config problems. I too seriously doubt the laydown servo affects the CG in a quantifiable way.
vti-chris 04-18-2005 04:59 AM
[&o][&o][&o]
Here is a link of the lay down servo math calculations...!
http://www.nitromonkey.com/servos.shtml
MBX5T Maniac 04-18-2005 08:05 AM
okay, so i suddenly don't want the pcr.
dryvr 04-18-2005 08:22 AM
The hyper7 pbs is definately race worthy and "one" of the toughest rtr's out there. Same goes for the pcr version. It's just a matter of preference wether you get one over the other. Personally, I would get the Hyper7 pbs over the pcr.
MBX5T Maniac 04-18-2005 08:33 AM
and why would that be? because it's so tough?
vti-chris 04-18-2005 08:35 AM
:eek:
Engrose 04-18-2005 09:02 AM
ORIGINAL: rustler08
They are both tough, but as stated many many times, the laydown servo is basically just a fashion thing. It's a lot easier to deal with the normal servo-layout. Therefore go for the PBS
MBX5T Maniac 04-18-2005 01:24 PM
RE: SO WHAT'S THE DIFFERENCE?
so the steering on the pcr is more complex, therefore, it is more prone to break
Engrose 04-18-2005 02:00 PM
1 Attachment(s)
No - it's just more difficult to access the servo.
The gas/brake servo arrangement is more complex at the pcr as seen on the picture.
MBX5T Maniac 04-18-2005 04:57 PM
so just more parts to replace if they break? and is the reaction time slower or not as powerful due to more parts? and does that setup break faster than the other setup?
MBX5T Maniac 04-18-2005 08:20 PM
is this right? /\/\/\/\/\/\/\/\/\/\/\/\/\/\/\
Foxy 04-19-2005 01:37 AM
Rustler, you're in danger of getting ignored because you keep asking irrelevant questions. Your questions have been answered. Everybody thinks you should get a PBS. What are you flapping about? Go out and get one!
For the record: PCR has laydown servo, has no discernible advantage or disadvantage in terms of performance or durability. It is a pain in the ass to work on though. I didn't know this, but Engrose knows what he's talking about so I am sure he is correct if he says that the throttle/brake servo positioning is similarly different on the PCR. Again this does not necessarily mean that the performance or durability is affected, it's probably just a side effect of the different layout. You're obviously not racing at a competitive level, so the extra $$$ spent on the PCR would not be worth it either.
You have your answers, make a decision.
MBX5T Maniac 04-19-2005 11:43 AM
i will be racing. im going to pick up the pbs once i have the money. some guy at my lhs said that ofna buggies were crap. then i talked about the prospec, and he said it was crap, he said get the mbx5. im like, dude, you a freakin retard, the prospec is the mbx5 with the goodies. he's like, ooh, i thought you said the mbx4.
evilstoat 04-19-2005 06:14 PM
Dealspeed Date 4/18/2005 3:47:45 AM
I get more throw on the steering with the graphite lay down system than the standard hyper servo tray, with the standard one the servo arm would hit the steering plate earlier thus preventing as much lock on the streering, so installing my lay down system did make a difference over the stock servo tray, i do think as you guys have said the CG of this system does not make much difference to how the car handles though.
MBX5T Maniac 04-19-2005 09:08 PM
obviously it doesn't, just read that link. and you can trim off that extra material, instead of spending money on a different tray. right?
evilstoat 04-20-2005 04:30 AM
rustler08 Date 4/20/2005 3:08:19 AM
I am not getting a multi-tool to butcher my car just to save a few bux, this makes a considerable difference on the amount of streerng i get, all i am saying is tat i am happy with the value for money just to get the car around the track better, small things do make a difference in racing, now for bashing there is no point changing to this system only for looks.
MBX5T Maniac 04-20-2005 02:00 PM
how much does the graphite tray cost?
nitromonkey 04-20-2005 06:50 PM
Let me try to clarify the whole PBS/PCR thing. First of all, OFNA can be somewhat inconsistant in the way the RTR's and kits are packed, but here is how they were last time I looked.
PBS - Has pivot ball suspension, stand-up servos, plain stamped aluminum shock towers, aluminum bones without universals. The center diff is the 8 gear spider type. The servos and radio are slow and cheesy, the pipe is almost useless. [>:]
PCR - As mentioned earlier, basically a knockoff of the PBS except for the laydown servo which are not needed. [&o]
The two RTR's above are really very entry level and, ok to chase your neighbor's dog or cat with, but not race worthy.
PCR Pro Kit (best bet for the buck and very competative) - Comes with C-hub and pivot ball components for the front suspension. Comes with laydown servo tray and linkage, but the standard one is mounted. Shock towers are CNC aluminum as are the braces, all drivshafts have universals, all diffs are standard 6 gear type. Has quad brakes, chassis is milled out to save weight. :D
MBX5T Maniac 04-20-2005 06:53 PM
and i don't have the money to spend 200 bux on servos
Foxy 04-21-2005 02:10 AM
ORIGINAL: nitromonkey
I'm surprised to hear you say that. I have just ordered a PBS RTR (I am entry level when it comes to 1/8th buggies, but an experienced on-road racer), and I will start my 1/8th off-road racing career with this buggy. I have a reasonable budget on a monthly basis to inject into the buggy, and was wondering if you could recommend a series of hop-ups (not including the engine, servos or radio) to make the car more raceworthy? Anything you can recommend would be most helpful. Is the rolling chassis of the RTR Hypers really that bad? [:o]
Engrose 04-21-2005 05:06 AM
Just because some new guy says that the Hyper is bad, you don't need to panic. It's not bad at all from what I've seen. And I don't think that you need to upgrade a lot of things from the beginning. Take it in steps and see what breaks or what others at your track has upgraded. You have ordered better servo and a humppack as far as I remember.
Foxy 04-21-2005 05:18 AM
You remember well, young grasshopper. :D
I'm not worried, but I'm wondering if its a coincidence that the site with all the info on the PBS PCR differences mentioned earlier in this thread is called NitroMonkey, and so is this dude. Besides, I'll hear every opinion.
And another thing...how many cats and dogs can run 40MPH!!!!?
