RCU Forums
-   RC 1/8th Scale Buggies (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/)
-   -   Force .26 engine help!!! (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/3260951-force-26-engine-help.html)
yellowpasta2000 08-14-2005 04:13 AM
i have a jammin rtr and just broke it in properly and fully but the top speed isnt fast as normal and runs like its rich and when i lean it out it overheats BUT still runs like its RICH. please helpppp.
slicks 08-14-2005 02:10 PM
RE: Force .26 engine help!!!
yep - sounds like a Force .26! My suggestion is lean it out and run it until it pukes and then get a better engine. Your discription sounds very tipical of the Force .26 - I had one and have seen several of them on the RTR's here at our local track.
everspeed 08-14-2005 06:41 PM
If you add a couple of head shims, it'll cure your problems. And you're right. It's typical of force 25 and 26 engines.
Korn9898 08-14-2005 08:32 PM
what are head shims exactly? and where can u get them
slicks 08-14-2005 09:08 PM
A shim is like a very very thin washer that goes between the engine block and cooling head -- you can probably get them at Nitro House.
Everspeed - what clued you in to the need for a head shim? Do these engines have a pre-ignition problem? You have raised my interest here.
yellowpasta2000 08-15-2005 01:32 AM
u know the washer on the glowplug, cant u just add another one to make less compression?
everspeed 08-15-2005 07:10 AM
I tried the glow plug wsher, and it's not enough. The head shims actually go between the button head and the cylinder. I've had a couple of Force .26's, and they both needed a couple of head shims to get them to run right, even with 20% nitro. They actually made decent power after that too. The timing is too far advanced in these engines. Or they just simply are building them with too much compression. Same difference. I switched to an MC59 plug too. This made for less flameout trouble.
slicks 08-15-2005 03:46 PM
EVERSPEED -- thanks for the tip on the Force .26 - I'll have to remember that one. Not that I plan on owning another one - but like everywhere else - people get into the hobby via the RTR route (I know I did) and they end up with a Force .26.
MadForceDude 08-15-2005 07:29 PM
check for exhaust smoke, if u got no smoke at hight speed, you are probably very lean. some time VERY lean make your car act like very rich: low temp, lack of power, can't reach hight speed. IF your car lost is smoke with speed, try richen like half of a turn.
if this don't work, oh well, try something else:D
