bad diff
so how does your diff gears go out on a buggy that is only a month old? found a shim missing in the gears......
RE: bad diff
If you put it together then it could be shimmed wrong.
What buggy is it and what motor is in it? Edit: Also what diff is it (front, center, rear) and was there diff oil in it? |
RE: bad diff
if it is an RTR vesion it cane with grease instead of diff oil in the case. If you are a basher, this will contribute to an early death to the diffs... usually the center or rear first.
RE: bad diff
its a katana rtr .27, the center diff is the problem. i took it apart and grease in it and also 1 shim was missing. i drive the car hard so your probably right. should there be a shim for each gear? the book i have shows shims on all the gears. somebody over looked something at the factory.must of been made on a friday. so do u think some new gears and diff oil will do it?
RE: bad diff
Yep.
| All times are GMT -8. The time now is 10:00 AM. |
