diff
hi i want to know what the quickest way to take the center diff out of my hyper.
thanks:D |
RE: diff
Remove the 4 screws that hold the diff plate on and the throttle servo horn, lift off the horn and the whole center diff assembly, then just pull the blocks off with the disks and pads.
BEFORE YOU FIT THEM BACK IN !!! Slice the bearing blocks HORIZONTALLY across the center of the hole. This will aid the speed and refit times for future repairs. |
| All times are GMT -8. The time now is 07:32 PM. |
