THUNDER TIGER EB4 S2 HELP
MY THUNDER TIGER EB4 S2 starts fine but then it moves on its own and the car issent ticking over right. could you tell me why
and help me sort it out THANKS Or take 2 me on msn on [email protected] |
RE: THUNDER TIGER EB4 S2 HELP
Hey dude tried looking fo ya on MSN but ya not there.Anyway can ya perhaps provide a little more detail of what your buggy is doing?
my dad turned the high speed neddle from closed 2 1/2 turns.then the low speed 5 3/8 turns on starting the car wanted to go with trottle in neutral, and what looked like unburned fuel coming from exaust.i have already run in from new with no problem, i have not moved the trims on transmitter dont yet no how to this
ps.you can e mail my dad on [email protected]
thanks matti. |
Did you guys get it worked out .... sounds like the buggy is new ... I would check for clutch drag ... might be a broken spring or something simple like that .... happend to me but the flywheel had come loose a little and the clutch shoes where rubbin' on the face of the clutch bell. Does it sound like that might be something to at least look into for starters .. ??
:eek:misco its your idle speed setting m8 turn it out so its reving slow if it revs too high it will move on its own ;)
thanks i try at the weekend if ican get dad out. is m8 sec b 18 manual.
starter spring snapped, can i buy just spring, or need new unit
Easier to buy a new pull start.
Good to see someone else with the thunder tiger on here, I took mine to the track last saturday and it handled very well on the track. If I get a decent motor it could be a definite contender, I bought mine used and the motor is tired.
Hope your get your problem worked out. |
| All times are GMT -8. The time now is 12:38 AM. |
