PULLSTART!!!!!!!!!!!!!!!!!!!!!!!!
hi all what is the best pull start to use on my xtm xterminator 2 as i have gone through
3 of the standard one's any suggestions thanks bobby d |
RE: PULLSTART!!!!!!!!!!!!!!!!!!!!!!!!
Pull starts are just like that.
Treat them well with short tugs and make sure your engine is well primed and tuned and they should last reasonably. Otherwise just get a starter box. |
I ran pull starters on all my RC vehicles till I got my buggy. I had very little problems with them but you defiantly have to use the properly. If you use them properly they hold up well. People all the time fuss about STS pull starters and I do not have a problem with them as well.
thanks guys i have an xtm rotostart i can start the buggy but as soon as hit the accelerator it dies
so i start it up again and it does same thing what could be the problem |
Is it a new engine? Are you quite new to nitro?
It sounds like its very rich on both needles but we might need a few more details to be sure. |
ive had the car since xmas last year and ive drove it quite a few times
so i dont think the engine has had it so to speak do you think my needles are not right |
Sounds like you need to re tune it. This is something you might have to do daily do to weather changes.
Is there oil/fuel dripping out of the pipe?
It sounds to me though you should start leaning your low speed needle. Do it in small increments of 1/12 turns and see if it starts to get better. |
the xtm sure start sucks the only rotostarts that i suggest is th hpi and team losi the xtm one melts to your engine and gets stuck pain in the @$$ me my friend had that problem it sucks i run hpi works perfect
| All times are GMT -8. The time now is 12:13 PM. |
