RCU Forums
-   RC 1/8th Scale Buggies (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/)
-   -   Robitronic Protos (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/7195977-robitronic-protos.html)
truck dude 03-08-2008 09:02 PM
Robitronic Protos
I just bought a protos buggy and it is idleing really fast, is that normal for a new engine.
Coopz 03-08-2008 09:50 PM
RE: Robitronic Protos
The wheels should not be spinning if its off the ground.
Lower the idle ajustment screw a fraction (anti clockwise) or maybe slightly richen the low speed.
truck dude 03-08-2008 10:35 PM
ok thanks
Dokioto 03-09-2008 01:42 PM
Sometimes it has nothing to do with the needle settings. If your servo trim is a little off (more throttle) it can seem like the engine is giving a very high idle. Not as big a possibility, but a thought.
BRUSSER 03-09-2008 10:00 PM
HEY:
HOW'S THAT PROTOS WORKING FOR YOU, I'M PLANNING TO BUY ONE AND WOULD LIKE SOME IMPUTS ABOUT.
truck dude 03-10-2008 08:10 PM
it starts easy, but right after break in i crashed it into a cement pole and the wheel broke off so i haven't gotten a chance to see exactly how good and how tuff it is.
Dokioto 03-11-2008 01:15 AM
Actually I think you have already tested how "tuff" it is:)
Farfa 03-11-2008 07:05 AM
robitronic stuff are good but i think protos its not so good...
i have robitronic mantis (truggy) and now i am coming to buggy world and i am going with the hyper 8.5. Robitronic mantis is a rly good truck but protos its more like a toy almost everything on it are plastic.
Dokioto 03-11-2008 03:27 PM
People don't like all the plastic but from what I have seen and heard it is fairly durable. I wouldn't give up on it, till I try one.
markind 07-17-2008 05:49 PM
We like our new Protos!! We just got it from Tower, $255 delivered.
Its only our 2nd RC nitro car, so we carefully read all the instructions, which are quite good, before we tried anything.
I got some high quality 25% fuel and got all the batteries charged up and went for the break in procedure. It took a few tries, but she finally fired up and I went through 4 full tanks of fuel at a nice low idle.
I then tested out the radio and attempted to drive it, but the steering mechanism was very far off, plus the engine, at its default settings, is running so rich it had no power to get going.
So, back to the lab bench for tweaking. Despite these minor setbacks, my son and I are looking forward to a lot of fun with this model.
markind 07-18-2008 01:05 PM
No problem! After about an hour of tweaking, we got the steering ironed out. The steering servo arm is not centered at neutral though. I probably have to remove the arm and put it on the next position. Close enough for training for now.
The first startup after all that was a little troublesome, but we got it going. Tuned it to running just a little rich now, but plenty of speed and some smoke at all thottle levels. Running under 210 degrees F. peak. Cool.
Burned through an entire quart of fuel and totally wore out the front tires and it seems the brakes are done too. Lots of power drifting, no major crashing. Flipped her once, but she landed right and kept going. That was neat. After the 3rd tank we tried some full throttle runs. She screams good.
Lotta fun!
Dokioto 07-20-2008 10:57 PM
Sounds good! Got a Ultra LX1 instead but i wouldn't mind picking one up after all these months.
Bangalang 07-22-2008 10:46 AM
so what are your temps at now... i got a protos that i modded out and my temps are around the 240-270 range.
markind 07-22-2008 11:50 AM
This engine is still new and tight so I am keeping it rich for now. Still around 210.
How do you measure? I just come straight down with the temp guage right over the glow plug. Seems to give the highest reading.
What mods do you recommend?
Bangalang 07-22-2008 12:57 PM
Aluminum Shock towers... Aluminium motor mount... i broke that right away.... maybe the bearing carriers.. Right now the thing is bullet proof...
And yeah....right down the middle for the measurements.. Axials like to run hot
markind 07-22-2008 03:04 PM
Cool, thanks for the tips! Too bad you're way out there in Chicago, we'd be racing! [sm=devious.gif]
I found a parking lot to terrorize at lunchtime today. She running great. Street tires working fine - did some power drifting and weaving between trees. Took a decent hit on a curb, nearly head on. No damage!
I am pleased that the street tires are not showing signs of extreme wear, but it was only a tank and a half today. And the asphalt was smooth, no dirt or sand on anywhere. I am still searching for a good off-road location to abuse. [sm=tongue_smile.gif]
Bangalang 07-22-2008 03:18 PM
Its most likely a good idea to get a extra gas tank... I broke mine and no place carried it... do all of your shopping at SK motion.. Or a hobby store that gets supplied by sk... they have every part and hop up part in stock for the protos... mine does not even look like a protos anymore... it will run with the rc8's
markind 07-23-2008 04:36 PM
Woo hoo! My son and I burned through another few tanks on a big parking lot with a nice big patch of dirt in the middle. Perfect for sliding around and donuts. Even hopped up some curbs and tore up some shrubbery. Took another flip and two more curb hits - No Damage!
This was the first time I got this model (or any other car model for that matter) completely filthy! My wife is a neat freak so I had to clean it up good before taking it back inside. Never had to do this before.
After thinking about it, I went for a bucket of soapy water and a large, soft paintbrush. Dig the mini-car-wash! Worked great. After mopping up, then I removed the body shell and just mopping with a rag and some WD-40 did pretty good. Washed and re-oiled the air filter, after-run oiling, now ready for more fun again!
This is a pretty solid model and is working out great for a couple of goofballs like us! :D
