***OCM KAOS DT-19 BUGGY THREAD***
1 Attachment(s)
Has anyone seen the OCM KAOS DT-19 buggy yet? Just got some of them in and they are really impressive. Come with all captured hinge pins and also ALL captured steering rod linkages (both sides) and also upper rear arms are captured. Inner hinge pin braces are about 7mm thick! Also all driveshafts and axles are made of spring steel. Comes with a THICK body stock and not a flimsy one also crimefighter design tires and high downforce wing. Radio box is 2 seperate compartments and fits real tight. Kit comes about 80% assembled, even the shocks but you just have to put fluid in them. Includes clutch bell, flywheel, aluminum clutch shoes, air filter and pipe springs. All CNC alumimum and also captured rear hub lower pins. Steering knuckles have 2 settings for adjustments to. Here are a couple pics I found online but will post my own pics soon.
RE: ***OCM KAOS DT-19 BUGGY THREAD***
i started a thread for ocm look thru the post it was a while back tho.
1 Attachment(s)
Here are some pics of the Kaos right out of the box.
Looks like a nice durable rig.
1 Attachment(s)
Here is 2 more...
:Di ran one for a couple races first time out the buggy rocked never got the setup right after that the thing pushed like a dump truck. another issues is the front uprights and the rear hubs in cold weather like to snap. but assembly of the buggy was a breeze and it was a pretty solid rig
ORIGINAL: ecocav04 :Di ran one for a couple races first time out the buggy rocked never got the setup right after that the thing pushed like a dump truck. another issues is the front uprights and the rear hubs in cold weather like to snap. but assembly of the buggy was a breeze and it was a pretty solid rig |
1 Attachment(s)
Here is my Kaos I got off of ebay to use as a demo! In pretty good shape. Will be putting a one of my spare motors (SH.28 6-port), RD Logics pipe, and some hitec 645mg servo's. Cannot wait to track test it. Have never seen one run or ran one myself.
ORIGINAL: vnmsgt ORIGINAL: ecocav04 :Di ran one for a couple races first time out the buggy rocked never got the setup right after that the thing pushed like a dump truck. another issues is the front uprights and the rear hubs in cold weather like to snap. but assembly of the buggy was a breeze and it was a pretty solid rig |
they are addressing the problem but it is still a problem all the currant kits have the same problems. its bad plastic it just depends on how long it takes the factory to fix the problem
ORIGINAL: ecocav04 they are addressing the problem but it is still a problem all the currant kits have the same problems. its bad plastic it just depends on how long it takes the factory to fix the problem |
ive talked to alan also. i reported that issue he said they are aware of the issue it just depends on when the factory will start making the change. its a cold weather issue more then anything. another thing is ditch the aluminum chassis braces for some plastic ones the car will be more forgiving to drive. and amain is no longer dealing with ocm so to all that buy them you might have to deal with ocm direct for a while or a smaller size business
ORIGINAL: ecocav04 ive talked to alan also. i reported that issue he said they are aware of the issue it just depends on when the factory will start making the change. its a cold weather issue more then anything. another thing is ditch the aluminum chassis braces for some plastic ones the car will be more forgiving to drive. and amain is no longer dealing with ocm so to all that buy them you might have to deal with ocm direct for a while or a smaller size business [link]http://holeshothobbies.com[/link]. If you do not see what you need email me and I can order it for you. BTW thanks for the info on the chassis braces. I might try that.:D |
vnmsgt,
I was just looking at your site and was wondering, what is your opinion on the OCM vs the Caster Racing ZX1-R that you have available? I'm looking to upgrade my 9 year old to a pro kit this season and am doing some shopping around. He's running a Matrix RTR thats been slightly upgraded and was thinking about something different. I dont really want to spend 500 dollars+ on a Losi, Mugen, Kyosho etc... Any pros and cons on either would be helpful. Thanks. |
ORIGINAL: Chopped02 vnmsgt, I was just looking at your site and was wondering, what is your opinion on the OCM vs the Caster Racing ZX1-R that you have available? I'm looking to upgrade my 9 year old to a pro kit this season and am doing some shopping around. He's running a Matrix RTR thats been slightly upgraded and was thinking about something different. I dont really want to spend 500 dollars+ on a Losi, Mugen, Kyosho etc... Any pros and cons on either would be helpful. Thanks. |
almost looks as good as the 8ight.
pretty cool that it comes in a bag instead of the box. |
ORIGINAL: vnmsgt ORIGINAL: Chopped02 vnmsgt, I was just looking at your site and was wondering, what is your opinion on the OCM vs the Caster Racing ZX1-R that you have available? I'm looking to upgrade my 9 year old to a pro kit this season and am doing some shopping around. He's running a Matrix RTR thats been slightly upgraded and was thinking about something different. I dont really want to spend 500 dollars+ on a Losi, Mugen, Kyosho etc... Any pros and cons on either would be helpful. Thanks. |
ORIGINAL: RHODEISLAND almost looks as good as the 8ight. pretty cool that it comes in a bag instead of the box. |
be aware that the car you have handles like dog poooh compared to the evo kit. ocm is a great car i wish i didnt have to run the computer at races. if i had more time to play with setup i would still have both my evo buggys.
ORIGINAL: ecocav04 be aware that the car you have handles like dog poooh compared to the evo kit. ocm is a great car i wish i didnt have to run the computer at races. if i had more time to play with setup i would still have both my evo buggys. |
i bought the non evo verson on a very smooth track with small jumps it should rock on a rough rutted track it failed pretty bad the shocks are short and it restrics alot of droop. get the evo kit on it spend a little bit of time setting it up and have a go and there 2 worlds apart
ORIGINAL: ecocav04 i bought the non evo verson on a very smooth track with small jumps it should rock on a rough rutted track it failed pretty bad the shocks are short and it restrics alot of droop. get the evo kit on it spend a little bit of time setting it up and have a go and there 2 worlds apart |
Just got the OCM ready to run this weekend. Put some extra stuff I had laying around for now just to get it up and running. I put a SH.28 6-port motor in it, 2 Hitec 645MG servos, and a RD Logics Pipe along with a extra spectrum. One thing I can say so far is the drivetrain is real smooth. The way the servo wires are routed and on/off switch wires are really nice and the radio tray is 2 separate compartment which is real nice.
ORIGINAL: vnmsgt ORIGINAL: ecocav04 i bought the non evo verson on a very smooth track with small jumps it should rock on a rough rutted track it failed pretty bad the shocks are short and it restrics alot of droop. get the evo kit on it spend a little bit of time setting it up and have a go and there 2 worlds apart you have 2 kaos dt 19 kits one is the evo the other isnt. the shocks look the same but one has blue springs and one has white the blue spring shocks are alot longer then the regular ones and the shocktower location playsthe biggest role in the handeling of the car |
