glow igniter
her guys and girls how do i use the glow igniter is it supposed to clamp the plug and whats the part that has a spring under the battery plz tell me how to use it
RE: glow igniter
Yes it should clamp to the plug, under that pring there should be a couple of tabs to squeese it toward the battery, squeese it- then push it on the plug then release it. My brain hurts trying to describe this without pics[sm=drowning.gif]
RE: glow igniter
mine doesnt clip
RE: glow igniter
can u plz put photos plz plz plz because maybe im doing something wrong i have the ofna igniter that came with the ofna ultra lx 1 and im using the force 28 engine
RE: glow igniter
I dont have pics although your batteries likely dead ... if the battery is fresh its possible to just set the ignitor on ther glowplug without twist locking ( just push then twist )
RE: glow igniter
o ok ill try
RE: glow igniter
1 Attachment(s)
Bredrin,
1. Make sure that your glow plug igniter charge. 2. Make sure that you glow plug is working. 3. Your glow igniter still clamps down, the spring is internal. Push and twist, so that it locks onto the glow plug in the head. if the glow plug is not standing by itself, the igniter is not on. 4. Do not leave the glow plug igniter on. It will kill the battery of the glow plug!!! See the picture. If you need anything else, just PM me. Likkle more. |
RE: glow igniter
but do u have to pull the lever with the spring under the battery ?
RE: glow igniter
Yes, If you have one with that. You have to squeeze it down to open it, so the mouth / opening part gets bigger to receive the glow plug. then release, so it stays on. which glow igniter you have.
RE: glow igniter
ty so much for pics i have the ofna glow igniter that comes with the ultra lx 1
RE: glow igniter
RE: glow igniter
ok ty i got it now ty so much i never knew u had to push it on so hard
RE: glow igniter
Happy Driving.
RE: glow igniter
ty
| All times are GMT -8. The time now is 01:37 AM. |
