Droop gauge question!
I have purchased the proline 1/8 buggy droop gauge while at the same time not knowing how to use it. http://www.amainhobbies.com/product_...oducts_id/4498 I see that Hudy has chassis blocks for there droop gauge. Do I need blocks for my gauge? If so can I just make them if I had the correct size? Could someone please take a minute and tell me the proper way to use this tool, or direct me to a (How To) that will help me with this particular gauge. Thanks so much. Ken
I have a losi 8ight. |
RE: Droop gauge question!
I don't know how to use that gauge, but this is how The Drake does it, http://www.youtube.com/watch?v=H99PKqsUZjA
I do have a digital caliper tool. Maybe I will just stick to measuring from the top shock nut to the bottom. There is limiter/droop specs on the Drake set up sheets that should give me a good starting point. 95mm front and 106.5 rear. Did I really need to spend $8 on the droop gauge that I don't know how to use, well, maybe. When I get to the track in May (when the snow leaves in Canada) I will ask some experienced guys how it works unless I here before then. Come on (Integra) where is your 2 cents on this.
should have waited till the end of this month the tools that drake have will be out by then and they are cheap. or if you really want you can do it with a caliper but that might be a little harder to do.
Stupid question: How do you adjust the droop? I noticed on my 8ight that one rear shock has more droop than the other (using a non-digital caliper that doesnt show mm) and was wondering how to change it. I was thinking of unthreading/threading the shock but that didnt sound right.
ORIGINAL: Chris_RC Stupid question: How do you adjust the droop? I noticed on my 8ight that one rear shock has more droop than the other (using a non-digital caliper that doesnt show mm) and was wondering how to change it. I was thinking of unthreading/threading the shock but that didnt sound right. the screw that goes through the lower arm and push's on the chassy is how you adjust droop.....Kman43 i personally dont know how to use the Proline droop guage.....some cars you measure droop with the car on a Wheel and measure whats under the arms....and that is what the proline guage is for....but the losi uses shock length...so the tool is basically useless to you with a losi...No worries it was 8$ right ? Lethal19 the tools losi is releasing is a Fold up car stand and a ride height guage....Not a droop guage. |
Thanks alot INTEGRA!
Thanks Integra. I will stick to measuring shock length.
Anytime guys. [sm=teeth_smile.gif]
| All times are GMT -8. The time now is 02:23 PM. |
