RCU Forums
-   RC 1/8th Scale Buggies (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/)
-   -   Steering Problem (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/8740670-steering-problem.html)
Dirtdigger04 05-04-2009 06:15 PM
Steering Problem
Hey, i have a Sportwerks Mayhem, and i have a problem with the steering. When i turn it to the right, it goes back to neutral, and the car can go i a straight line, but when i turn it to the left, it doesn't turn back to neutral, and turns a little bit to the left, so i won't go in a straight line. I put a new HT servo in it, but i still have the same problem. Please help me with this. Thank You.
gearjammen 05-04-2009 07:00 PM
RE: Steering Problem
adj the trim on your transmitter.first though take the horn off the servo turn your radio and reciver point your wheels as close to center as you can then put the horn back on adj the trim with your transmitter.make sure the horn is not slipping on the servo differnt servos differnt splines.
Dirtdigger04 05-04-2009 08:25 PM
I tried adjusting the trim and i am sure nothing is slipping. Is there anything else causing this.
driller2948 05-04-2009 09:00 PM
It could be your rx! Can you check your servos with a another rx like one of your buddies?
tommygun32 05-05-2009 03:09 AM
Another idea. Make sure your servo saver isn't too tight. Also check that the bearings in your servo saver aren't shot. Double check the range of travel of your wheels and turnbuckles with the servo disconnected and make sure nothing is impeeding that movement. Good luck.
