Would You Say This is an Air or Ice Boat?
Hello All, I started building this about 10 years ago.. I have always called it an Ice Boat… Or should it be called an Air Boat? Either, Or, It’s still fun…
<xml><w:LatentStyles DefLockedState="false" LatentStyleCount="156"></w:LatentStyles></xml><style> Style Definitions */table.MsoNormalTable{mso-style-name:"Table Normal";mso-tstyle-rowband-size:0;mso-tstyle-colband-size:0;mso-style-noshow:yes;mso-style-parent:"";mso-padding-alt:0in 5.4pt 0in 5.4pt;mso-para-margin:0in;mso-para-margin-bottom:.0001pt;mso-pagination:widow-orphan;font-size:10.0pt;font-family:"Times New Roman";mso-ansi-language:#0400;mso-fareast-language:#0400;mso-bidi-language:#0400;}</style>One of my early very rought versions:
Ok, the “Icy Air Ski” will turn on a dime with the oversized rudder, as it's just as wide as the prop. I added a new prop, the other smaller 3 bladed one was clocked at 45mph on snow covered ice, no wax needed. I just fixed the skis as I was a little anxious to get it running again, so I took it outback in the gravel lot. It had no problems with the newer prop gliding over the gravel and going up hill in the grass. But once I started doing 360’s they let go… HA HA!
