Hull size for a .15
Newbie here, trying to figure out hull sizes.
I have an old hull I build as a kid, with no idea what I was doing, its 8x17, balsa covered with epoxy. It was powered with a .061 that I never could get running. Its all square edges with a rounded front, single rudder.
Should I use this hull with my new motor or build a new one? I was thinking foam covered with glass 12x24, but I think it may be too big and heavy for the .15.
What will end up lighter, balsa and epoxy or foam and a single layer of glass?
Should I make an even smaller hull for the .15? 7x12 maybe? I dont have the motor and prop yet, but I believe its a 8"x4 pitch.
Thanks!
Thanks!
I had a few mins at work. Knocked out a 7x14 hull blank, and cut a 12.25 wide one I can make another out of if its too small. I am going to try to make a tower that could be swapped around if needed. I have more foam too if I need another larger one. I cut a 10 degree bevel on the sides.
Still looking for opinions as to size to motor.![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
![](https://c4.staticflickr.com/8/7729/17621691074_54d10de222_z.jpg)
![](https://c1.staticflickr.com/9/8843/18056500570_33867dceb8_z.jpg)
![](https://c1.staticflickr.com/9/8869/18056482828_e1352c4cb3_z.jpg)
![](/forum/images/badges/premium_member.png)
For a .15 using like a 7x5 or 8x4 prop, plan to keep your weight to about 1.5-2# MAX. You'll be lucky to get 3-3.5# thrust from a .15 so getting anything over 2# to move with any authority whatsoever will require a bigger engine. I'd be looking at 10x16 or so for a hull size. 1.5 X prop dia. for width and 2.5-3 X prop dia. for length is a good place to start.
I'll have to find out
The only thing I'm worried about is my electronics box is pretty heavy.... Its thick walled plastic with a gasket lid. I'll have to weigh it.
I put a coat of epoxy on the bottom and sides this evening.
![Smile](https://www.rcuniverse.com/forum/images/smilies/smile.gif)
Are you planning to run on dry ground or on water?
The fuel tank should be mounted so the centerline of the tank be mounted in line with the spraybar of the carb. That is ideal. You can have the fuel tank centerline be mounted slightly below the spraybar centerline but you may encounter fuel draw problems when the tank gets low. Car engines tend to have larger carb chokes so this can cause further fuel draw issues. Be sure to use muffler pressure to the tank.
Heres a link to my twin .15 engine wood/foam airboat that is too heavy. Note where my fuel tanks are. http://youtu.be/uHB3Nh2lbgY
Looks pretty good so far. I'd suggest incorporating some adjustability in your engine mount to allow you to move the engine back and forth to adjust the Center of Gravity. If the engine is too far back, it will want to dig in and plow water. It's balanced properly when the hull hangs level or slightly bow heavy when you hold it up by the prop.
![](/forum/images/badges/trading_plus_member.png)
Hi here is link to my new airboat which runs an OS15 engine.
https://www.youtube.com/watch?v=f_x0sO6hGfo
Have had several better runs with this as I found that I had fitted prop on back to front so speed has now much improved with it the right way round.
Length is 650mm, beam is 250mm, engine is running 8'x6" prop.
Awesome fun, look forward to seeing yours running!![](https://www.rcuniverse.com/forum/attachment.php?attachmentid=2101795)
