Go Back  RCU Forums > RC Boats > RC Airboats
Reload this Page >
New Builder/First Air Boat
RC Airboats Discuss R/C Airboats here!
Old 03-26-2017, 03:13 PM
  #126
NEW222
Ok. Sorry to hijack this thread for a moment, but I have a question regarding your post below, or above (wherever the forum puts it). Anyways, since we are talking about this airboat, and the rudders, could I just clarify something. From my reading your post, I am led to believe that it would be better to make my rudders longer (further away from the boat), rather than taller? I am just asking to clarify as I was just about to make a new set the original depth, but double the height, as I have turning issues myself. But now, I am thinking I would be best to build them the same height, but 2" longer? Thank you.
Originally Posted by 1QwkSport2.5r
The only problem you could run into is whether the paint is chemically compatible with epoxy. Generally speaking, 2-component finishes are compatible with other 2-component paints. 2-component means the material uses a catalyst/crosslinker/hardener. There are limits to this however - polyester resin is 2-component, but will not adhere to epoxy and vice versa. I know for a fact that commercial 2-component waterborne polyurethane will stick to epoxy as does oil based polyurethane.. but epoxy won't stick to polyurethane. Some automotive paints are urethane based and others are lacquer based. I think it fair to say that a urethane paint will be a "slam dunk" whereas lacquer may not. You would need to do some test spots to determine adhesion before painting the whole thing. At minimum, use scotchbrite to break the sheen of the epoxy to aid adhesion. Better yet, use some 220-320 grit abrasive (sandpaper) to break the sheen. A quality finish/paint should adhere provided the substrate is adequately abraded. I may be making a mountain from a mole hill, but I'd hate for someone to have their paint peel.
As for the rudders - I haven't found a huge benefit from the height of the rudders as much as depth. Meaning a rudder that is wider (protrudes farther off the back of the boat) will provide more positive control than a narrower but taller rudder. If you read my thread about my SI3 flat bottom boat, you will see the "evolution" of my rudders on that boat starting with the rudders the plans outlined and the two revisions I made to improve steering control and response. Post #43 http://www.rcuniverse.com/forum/rc-a...-bottom-2.html
You don't expressly need to have your rudders' height match the height of the propwash. 1/2-2/3 of the propwash is totally good provided the width of the rudder is adequate. Do test your initial rudders first though - if it doesn't respond quickly or turn sharply, you will need to adjust the throw and/or the size of the rudders.
Besides building a strong hull, your rudders need to perform A-1 perfect. It's a real PITA if your boat don't turn for crap and she gets stuck in the weeds requiring going for a swim or canoe ride to recover it. I learned the hard way a time or two.
Old 03-26-2017, 03:37 PM
  #127
1QwkSport2.5r
1QwkSport2.5r's Avatar
Did you read the post and look at the pictures referenced in my last post? The pictures will show exactly what I meant in my last post. In a nutshell, it isn't necessarily required to go up in height as that can raise your CG to an unhappy point. Going deeper makes more sense and does work very very well in my testing. I did raise the height of my rudders in my last referenced post, but only by about an inch. I added almost double the depth though - which did the trick. The top left photo was the first rudder I made per the plans. Second rudder is too right, and the last one bottom left. Original rudder compared to final rudder bottom right.
Old 03-27-2017, 06:28 PM
  #128
NEW222
Yes, I did read it, but just wanted to concur. So it looks like I will be cutting 2 new rudders next week!
Old 03-27-2017, 07:06 PM
  #129
1QwkSport2.5r
I didn't want to come across as being snotty, but I thought I was clear enough. If I wasn't, my apologies.
Old 03-28-2017, 11:33 AM
  #130
trapper7
Back to my problem with the epoxy not drying. I am fairly convinced now it was an issue of poorly mixing the two parts, not the ratio. The last two batches have been just fine and were mixed well.
Old 03-28-2017, 11:35 AM
  #131
1QwkSport2.5r
Did you thin the epoxy at all or just using it straight?
Old 03-28-2017, 11:45 AM
  #132
trapper7
It is finish resin. I have just used it straight. Any recommendations?
Old 03-28-2017, 12:30 PM
  #133
1QwkSport2.5r
That's what I use as well. If you do thin it, use acetone or methanol, and only add maybe 10%. It doesn't take much to thin it. Also, only thin the resin AFTER mixing the resin and hardener thoroughly.
Old 03-28-2017, 05:57 PM
  #134
NEW222
Not at all. No worries. I just wanted to be 100% positive before modifying. So with that said.... longer rudders it will be! Thanks.
Old 03-28-2017, 06:01 PM
  #135
NEW222
Not knowing what finishing resin/epoxy you are using, I cannot help too much. But if it is something like West system, the mix ratios are NOT 1:1. There are special mixing pumps available for those. Others may mix 1:1. What brand are you using?
Old 03-28-2017, 06:02 PM
  #136
NEW222
Sorry, I just saw that the previous batches were ok. I would lead to improper ratios or not enough mixing.
Old 03-29-2017, 11:39 AM
  #137
trapper7
Sad to see the fine woodwork disappear beneath the gray primer!
ID:	2207538   Click image for larger version
Old 03-29-2017, 12:50 PM
  #138
trapper7
ANd the white! Gotta love the wheel barrow!
ID:	2207567   Click image for larger version
Old 03-29-2017, 03:53 PM
  #139
NEW222
Looks really nice. I understand trying to keep the wood showing. But this also adds a good waterproofing. Also I should note, I assume that your epoxy finally cured as you have painted it?
Old 03-31-2017, 03:40 AM
  #140
trapper7
1QwkSport2.5r
I plan to install the control lines this weekend. To get from the hull to the throttle means a bend in the line and i am wondering if there is a minimum radius for push rod movement or if they are pretty forgiving? I am using the all plastic rods; no cable.
Old 03-31-2017, 05:04 AM
  #141
1QwkSport2.5r
1QwkSport2.5r
The nylon control rods need a larger radius than the metal control rods. The section of cable that is glued within the hull as straight as possible and where the cables exit the hull give it as big a radius as you can without the cable binding. What I do is set the cable in the hull as I plan to install it and then radius the cable (for throttle as an example) to how you would mount it and test the cable to see how well it moves within the sheath. If it moves smoothly, then your set. If the cable sticks or doesn't move smoothly, adjust the radius until it does. In the end, you want the cable to move freely, so run the cable as short and as tight a radius as you can while still allowing free and smooth movement. If the cable binds, it will strain the servo.
Old 03-31-2017, 01:59 PM
  #142
trapper7
Worked on running lines this pm with my son...
Old 04-01-2017, 08:20 AM
  #143
trapper7
Now we are attempting to understand the transmitter set up...yes we are new to it all! Somewhat intuitive, but somewhat confusing as well! Wish there was a simple YouTube tutorial or something.
Old 04-01-2017, 11:15 AM
  #144
1QwkSport2.5r
Which radio do you have again and what are you trying to do?
Old 04-02-2017, 01:52 AM
  #145
trapper7
I have the Spektrum 4210 DX4C DSMR 4-Channel AVC Radio w/ SRS4210. I am trying to understand all the functions! I assume there are ways to control the speed of servo travel, distance of travel, trim servo position, etc.
Old 04-02-2017, 06:43 AM
  #146
1QwkSport2.5r
If you haven't read the manual yet, I suggest doing so. I have a DX3S, different than the DX4C in several ways, but it looks like the menus are similar. The menu requires pushing the roller button below the screen to open the menu, then scroll through the menus with the roller. Press the roller button to open the menu. The only settings I mess with are whether the servo needs standard movement or reverse movement (REVERSE), servo travel (TRAVEL), end point adjustment (EPA), and in some cases, sub trim (SUB TRIM). The menu "terms" I listed are within parentheses. I recommend setting the EPA to 100% and verify the throw. If you need more throw, I think you can go up to 125% I believe. If you need more throw than that, you'll need to adjust the mechanical linkage and/or change the servo horn/linkage position on the servo horn.
There are quite a few videos on YouTube that may be of assistance to you in learning how your radio system works and how to set it up. Might be worth a look.
Old 04-03-2017, 01:01 AM
  #147
trapper7
Thanks...perhaps its simpler than it appears. New terminology throws me off. I think I have it figured out.
Old 04-03-2017, 03:12 AM
  #148
1QwkSport2.5r
The AVC system may need to be turned off in a boat. I don't believe that radio is "marine ready", so it is worth reading into things a bit to ensure there aren't any hiccups when running your boat.
Old 04-03-2017, 02:23 PM
  #149
trapper7
yes, it appears off.
Old 04-04-2017, 04:19 AM
  #150
trapper7
Another potentially dumb question: how do you refill your fuel tanks? Do you have three copper tubes entering the tank or just two? Any pics?
