Warning WOOD props.
Warning WOOD props.
Wood props, airboats, WATER, do not match up!!!! Very dangerous!!! It only takes a little water to bust up a wood prop, then you have projectiles. Here are some pics after one 14oz tank of gas.
FL
RE: Warning WOOD props.
I never run wood on the ground vessels! Your looking for trouble. They turn up a little faster but not safe at all! Good advice Haljmac!!!
WI
There is so much about airboats that have no rules or reason.
If there were any one rule regarding them, it would be to not use wood props, for the reasons that Hal shows in the pics.
You may save a buck or two, but...........
