gas to electric
gas to electric
i have a airboat with a os 46 that i rigged up for catfishing but the loud gas motor and the tailrudder scare fish off
i want to convert it to elctric so it will be quiet
what would i need to get at least the equivilent to what i have know or maybe more torque and less speed, the boat pulls hs to pull out about 200 yards of heavy fishing line dragging a big weight and bait
thanks a bunch fellas
RE: gas to electric
http://www.hobby-lobby.com/speed700.htm Check these big boys out. It may be what you need.
Happy fishing
Happy fishing
ND
RE: gas to electric
how about a brushless outrunner? spins a big prop without a gearbox... a direct drive motor is going to probably be at too high of rpm, and running a gearbox is almost as noisy as a glow engine.
WI
RE: gas to electric
The Speed 700 has a lot of power, and by adding a torque ring to the can, you can improve the low end torque to allow the use of a little bigger prop. Also, you could easily use a sealed LA battery to power it for long durations.
I have two scale boats that I run. Both use a 6 volt battery powering a speed 600 type motor.
One has a 4.5AH and the other uses a 5AH (capacity) sealed rechargable. Both give me over an hour of cruising and you can use an inexpensive RC car/truch speed control for more precise speed control.
My Feedback: (21)
RE: gas to electric
Food for thought ....
Those electric weed eaters that almost everyone "toss's" away have SUPER good strong motors in them along with a nice rechargeable dry cell [8D] ( sorry , the speed control , since there is none , is something of a different color )
