Go Back  RCU Forums > RC Boats > RC Airboats
 Maximum engine size with standard servos. >
RC Airboats Discuss R/C Airboats here!
Old 10-15-2004 | 05:20 PM
Default Maximum engine size with standard servos.
Is there a max engine size I should use in order not to strip my rudder servo? I have just your standard plastic geared Futaba servos (S148 I think, not sure though). I haven't built the boat and my engine choices are .09, .15, .29, .35 abd .45. I know the smaller engines will be just fine and won't damage the servo but what about the .35 and .45?
Old 10-15-2004 | 06:42 PM
Default RE: Maximum engine size with standard servos.
You should be ok with all those engine choices - I like to make my rudder hinge point somewhere near the center of the rudder - so it does'nt take as much torque to turn the rudder at full throttle. Dave
Old 10-15-2004 | 06:45 PM
Selph-Inflicted's Avatar
My favorite motor to use is a .46 and I have no problem with my standard servos. Futaba 3003 servos
If you flip and hit your rudder, you may strip the gears if the rudder gets slammed to the maximum throw.
Old 10-18-2004 | 05:40 PM
Thanks guys.
