looking for duel rudder plans
Any one have plans for a simple motor platform for a .25 with duel rubbers? The single rudder system on my airboat just dont cut it. Does not turn like i want it to.
Email is [email protected]
CA
RE: looking for duel rudder plans
Check out this forum.
http://www.rcuniverse.com/forum/fb.asp?m=2381675
My Feedback: (21)
Before you re-do your rudder and possibly mount , tell us what the boat is doing , or not doing , that you do not like . We might be able to tell you what might be wrong . Could be a simple fix rather than you having to re-do the whole mount .
boat is 28inc long by 10inc wide. 3 keel bottem with a .25 motor. It just dont turn that good for me. I know a bigger motor would realy help but i cant build one of them. Yet.
FL
Could you get a picof the rudder set up and bottom of your boat?
28" is a bit big for the .25, in my opinion. My boats are 26"x13" and powered by 46's.
Do you mean a 3" keel protruding from the bottom? If so this will keep the boat from sliding when turning . I'm not sure of how you are wanting the boat to turn. Do you want it to track like its on rails when turning or are you wanting it to slide when turning?
Rudder is about 7 inc from prop and it can be moved closer. I was just givin an MDS .48 and gona see how thats gona do in the boat befor I redo the rudders.
I think my problems solved, the MDS .48 is giving me tomuch power and tomuch speed.
I do have another prop pitch question. What is a good pitch? I only have 9inc from shaft to base of boat so a 9inc prop is all i can use unless i want to make a new mount or raise it up a bit. Right now im using a 9x5
