Go Back  RCU Forums > RC Boats > RC Airboats
 Inline twin >
Inline twin
RC Airboats Discuss R/C Airboats here!
Inline twin
Old 12-17-2005 | 01:26 PM
asmithnc's Avatar
Default Inline twin
One of the latest projects on the table.
Old 12-17-2005 | 02:30 PM
jasperrc's Avatar
Default RE: Inline twin
I sure hope you post some vids when you get her on the water. I want to see how she runs!
Old 12-18-2005 | 07:46 AM
RS 38-40's Avatar
This is amazing comming or going .
Old 12-18-2005 | 09:53 AM
The more I look at this project the more I can see a boat that will handle well. With the 2 points of pulling/pushing force in center line, it should stop any spin outs, and help it to give a even smooth turn. What are your plans for the rudder system? Wonder if rudders between the engines would work? On the props are they the same in size?
Old 12-18-2005 | 07:21 PM
asmithnc's Avatar
The final prop set-up will be a 11 x 6 puller and a three bladed 9 x 6 pusher. The rudders will be a custom aluminum twin set-up.
Old 12-23-2005 | 06:29 PM
max cook's Avatar
sweet!!!!!!!
i like those gas tanks
i also like those stacks of OS and Evolution engine boxes
Old 12-23-2005 | 07:41 PM
Selph-Inflicted's Avatar
This is one very unique build.....I can't wait to see it run! [X(]
Speaking of seeing it run.....when will that be?
Old 12-23-2005 | 07:42 PM
Vertical3-D's Avatar
My Feedback: (20)
Thats some nice work, Should be a real power house, heck its all engine, the tanks are nice and the way the throttle linkage is run is nice, simple and direct, id love to see a video when its done, My 1/4 scale will be done to the point of a test run by tommorow, I cant wait, today i put a wire to the throttle, gave her a tug and it went skidding across the floor...
Old 12-24-2005 | 03:38 PM
asmithnc's Avatar
Thanks guys... The tanks is a one piece set-up. I tried to keep is simple and a single tank set-up divided into two parts. I have taken some time off from work and will try to finish buy the first of the new year.
Old 08-18-2006 | 03:38 PM
asmithnc's Avatar
Finally got the time to do a little work on the twin. She is not complete but ready for some water testing.
Old 08-19-2006 | 12:32 PM
asmithnc's Avatar
Just a test before the run tomorrow. http://www.rc-airboats.com/gallery/v...uccessful_test
Old 08-19-2006 | 03:27 PM
TERBObob's Avatar
My Feedback: (21)
Just curious if I seen the wrong thing here , but , it sure appeared that the air coming off the props was going more to the sides , rather than the back .
Curious ----- did you tach each engine and see the results ? Was the rear engine cranking faster than the front ?
Also , looks like both props are the same diameter , are they the same pitch as well ?
Old 08-19-2006 | 03:48 PM
asmithnc's Avatar
MR. T- BOB
The opening part of the movie said ( Both running tractor) sorry if I was not clear. I finished the break in today and both had tractor set-ups. I broke them in one at a time. Then I cranked both of them up and made the short video. Yes the props are the same diameter and yes the prop wash was canceled out in the middle causing an arch affect. It sure put a smile on my face. The final prop set-up will be a 11 x 6 puller and a three bladed 9 x 6 pusher for the first run tomorrow.
Old 08-20-2006 | 01:05 PM
Can't wait to see the vids of this incredible creation.
You have definitely put alot of thought and engineering into this boat! Good Job!
Old 08-20-2006 | 08:16 PM
asmithnc's Avatar
I had a chance to put the boat on the water. First , I had a time with the twins they kept flooding. I since found the problem but only after I got home from the run. Here is a small video of the warm up. We thought the video camera was off during the start up (thought wrong). When the boat hit the water the camera was turned off (oops). Never got the twin running together on the water.
http://www.rc-airboats.com/gallery/v...d=Twin_warm_up
