not fast enough
not fast enough
reading some post in here people talk about almost flipping or blowovers. my boat has never came close to doing this so i figure it must be under powered.it's 39 inches long 19 inches wide and weighs 16 pound running a mds78 and a 12x6 prop, gps-ed at 24 mph,after some advice recieved in here i removed the tank stand and put it at the back and it now skims across the water sweet slightly bow up.the ? is do you think a ST 2300 would be a good motor or would it be to powerful.the 78 sucks the fuel up without any problems would a st2300 do the same and i have a 12 1/2 x 11 bolly prop is this a big enough prop for the ST because if it is i wouldn't have to change the motors height not that that would matter. i think the ST comes with a 18x6 and a pitts muffler
My Feedback: (21)
RE: not fast enough
Whoa ....
Did I read right ? 16 pounds ? Is a pound over in OZ , the same as it is here in the States ? 16 ounces to a pound ?
Thats a LOT of weight .... How , or should I say why , is this hull so heavy ?
My canard running a 1.48 weighs half of yours running half the engine ....
Please let us know what you made your hull out of , or what you did that makes it so heavy .
RE: not fast enough
hi 16 1/2 pound or 7 kilos rtr I made the ribs ,sides and front out of 6mm or about 1/4 inch ply,had heaps lying about, then i made 2 fibreglass sheets to cover top and bottom then i gel coated it which probably added 1 1/2 kilos or about 3 pound wish now i just painted it.This was and still is the only boat i have made no plans no idea of what i was doing first time i had any thing to do with nitro motors, only airboats i had seen were on Gentle Ben abouts 20 years ago,after i built it a friend told me about r/c uni. and after i looked at and read most of the posts i realised that it was to heavy but since it seemed to get up and go fairly well,quicker than my mates 2 foot bodyboard with a super tigre .40, i wasn't to worried but i now know it could handle a lot more speed thats why i asked the ? about a bigger motor.it's as solid as a brick s;;thouse which is good because there are big rocks all around where i use it a large tidal rock pool and it just bounces over them
My Feedback: (21)
RE: not fast enough
Hey ... I thought that phrase ( brick pooper house ) was an Amercan thingy ...
Anyway ... weight wise ... yes , a bigger engine would DEFINATELY do you better ( more HP , not so much the R's )
I would suggest a weed eater style 2 stroker , but , I think you might have probs then with the small size ( think it might be a tad too small for a weed eater engine in both length and width , but , with the heaviness of it , she might fair better than I think )
And if you go with nitro ... whew ... make sure , you have DEEP pockets ... those big engines when get over a 60 size , kinda like the juice a LOT more than their smaller buddies ( engines smaller than 60's - including quite a few of the 60 also )
But ya know ... top speed is NOT always what makes folks happy ... better handling , better stability ... these are VERY important . ( more so , than speed )
So , don't worry about the weight .... just do some changes ( motor ) and you'll be good to go .
OR>>>>>>> you can leave it the way it is , and learn to run an airboat , and have TONS of fun while doing it , and then later on , down the road , you can always change out the engine for a larger HP one , or , you could leave that set on the shelf , and build a new one . Then , you have the original and know what to do , and what not to do ....
Either way .... welcome to the FANTASTIC fun world of RC airboating and hey .... remember ... its all about FUN . ( and being careful too ! )
Keep us posted ... and by all means ... if you get out there and run more ... post some pics and PREFERABLY .... some vids . we ALL love vids here !
RE: not fast enough
This [link=http://m-ab-a.com/Gallery/Cajun_Gator/HPIM0720a]Cajun Gator ST2300[/link] is 40" x 19 1/2" weighs just a tad under 15lbs RTR. I'm turning a 16" x 10" 3-blade pusher prop. The speed with a rador gun is 30mph(cheap gun so may not be right).
[link=http://m-ab-a.com/Gallery/albums/Cajun_Gator/purple_people_eater.wmv]ST2300 1[/link]
[link=http://m-ab-a.com/Gallery/albums/Cajun_Gator/St2300.wmv]ST2300 2[/link]
[link=http://m-ab-a.com/Gallery/albums/Cajun_Gator/PurplePeopleEater.wmv]ST2300 3[/link]
MO
RE: not fast enough
Now thats some hill climbing on that last video Mr Gator
wish my Gasser could do that [&o]
Video of my gasser on water
[link=http://m-ab-a.com/Gallery/albums/kevinboatman/April_21_06_rc_gasser_003.avi]click here[/link]
its not super fast but very stable in rough water
RE: not fast enough
just got the bigger motor G2300 for $153.50 AU about $100US i think. i will put it on shortly and give it a run my mates got a camera so i will try and get some vid of it. Now i have a spare motor ,better do something about that, dam.
RE: not fast enough
ORIGINAL: noslienk
