twin engine gasser
RE: twin engine gasser
well did alot more to the enegins think its to heavy the engines and stand are 11 pounds and the hull it just over 10 with makes 21 is that to heavy i have shaved as much rubbish of one engine the ive got the servos battery petrol tank and fiber glass and paint
for the paint job i was going to do it a nice bright orange then i want to make some stencils of flames then do green flames over it and on the engine stand ime going to run it with homemade exhaust becuse the origanals look crap
and thay drip oil pics very soon
PA
Looking very nice so far!
I assume that you will find a matching prop for you second engine...
... and that the engines have a very similar CC, RPM range, and HP (I hope they are both the same engine but by the looks of them, they arn't)
...Just my little $0.0002...
Did you test how well she floats?
Oh, and one last thing, when you're finished, we would all LOVE some videos[8D]
PA
ORIGINAL: Selph-Inflicted
Oh Yeah!! I believe this will be the first twin gasser that I've seen.
Nice, keep up the good work!
[link]http://m-ab-a.com/Gallery/Fun_Run07/cajun_gator_fun_run_012[/link]
And as he said above, keep up the good work!
PS, If I have assumed anything in my posts incorrectly, please correct me![sm=red_smile.gif]
thay are exasctley the same engine from the same trimmers one was 1 yer older than the outher but not much use it had 2 more fins on the flywheel thats is .
PA
OK, thank you for clarifying.
Well, its been done before, though rarely, so it is possible. What are your hopes for top speed?
IMO, she should do 25-30 easily - though I am not really an expert on gassers (I'm all electric - it's cheaper!)
tried it with one engine with a 13x 7 apc went was crazy got on the plain quick was doing a good 20mph if i culd keep it going straght
Wow that is going to be some air boat take it two engines go same speed use rudders for steering be hard to keep it going straight bad enough with one engine very nice
here yah go guys sory about the quality it was done on a fone
http://www.youtube.com/watch?v=wZmeZYN8Mm0
