GASSER WONT START
GASSER WONT START
Ok guys last thing my 31 cc gasser will not start.I tested the magnetos put new line on it checked the spark and even tried to spray streight carb cleaner into it. I took the old pull start off and clutch to convert it to drill start.Thats about it any help?
RE: GASSER WONT START
Try your question here http://www.rcuniverse.com/forum/forumid_92/tt.htm
You will get good responses.
-Gary
-Gary
WI
If it ran before you took the pull start off, the problem might be that the drill is not turning the engine over fast enough to generate a spark.
