Go Back  RCU Forums > RC Boats > RC Airboats
 will this work >
will this work
RC Airboats Discuss R/C Airboats here!
will this work
Old 01-19-2010 | 10:25 PM
Default will this work
can i use a 3 channel receiver for my airboat or do i need a 2 channel all most done
Old 01-19-2010 | 10:35 PM
Default RE: will this work
what radio do you have and what Rx you are wanting to use?
Old 01-19-2010 | 10:41 PM
i have a jr  from my team losi lst and the servos r like new and the receiver is new
Old 01-19-2010 | 10:48 PM
I'm still some what in the dark of what you are wanting to do. If you have a matching set Tx and Rx yes a 3 channel will work on the airboats. If you have a 2 channel Tx and a off the waall 3 channel Rx chances are that the Rx will not work with the Tx.
Old 01-19-2010 | 10:51 PM
yes it is a maching set
Old 01-19-2010 | 10:52 PM
then you are good to go. planning to use the 3rd channel?
Old 01-19-2010 | 11:16 PM
maybe a jack plate ? don,t know yet any ideals i like to do mod.s to my boats because i dont have much invested in any of them
Old 01-19-2010 | 11:18 PM
Old 01-19-2010 | 11:20 PM
jack plate on a airboat? what type of jack plate?
Old 01-19-2010 | 11:26 PM
to  help keep back of boat stable when full thottle
Old 01-20-2010 | 02:26 PM
You could use it for a trim plate, but a fixed trim plate is easier to set up and cheaper. If you use a servo to move the trim plate up and down with the servo connected directly to the trim plate, you will need a strong servo. If you use a switch/electric motor setup for either a screw drive or a gear assembly you are looking at $ and complexity and more things to fail and give you headaches. Not to mention the possible weight penalty. Dennis
Old 01-20-2010 | 04:33 PM
im going to just put a fixed trim tab on it and be done
Old 01-20-2010 | 05:21 PM
I don't know where Keystone is but I know Graves Hobby Center(Orlando) carries several different sizes of them that are adjustable. Dennis
