My second build.
FL
RE: My second build.
Well here is an update, Almost got this one done hopefully will be painting this thing by Sunday. Weight of the boat w/engine is 19lbs so far, so when completed i'mshootingfor 23-25lb range
FL
I ordered some Frog spit slick bottom to paint on the bottom should be here next Friday. Has to cure for 72 hrs so might not have a vid till the following weekend.
FL
ORIGINAL: ptr34
do it in the sun and it should be dry in a couple hours. it doesnt take that long for frog spit to dry.
FL
Had a guy at work make me some decals for the boat. Think it's pretty funny because almost everthing you buy now is made in China.
FL
Well still waiting on Fed ex to bring me the frog spit, It has been shipped but nobody knows what happened to the package " Go Figure". But anyway we had alot of rain here and the backyard is flooded so I figured I would burn some fuel, Here is a short vid not the best in the world but just could not wait any longer. http://www.youtube.com/watch?v=JrEAPDAQ3Vw
FL
Yes it is very rewarding. Still have to play with the thrust angle a bit bounces around alot at higher speeds, could be a weight issue also not sure just have to tweak on it till it's right.
