RC Boats General Discussion Discuss general rc boating topics here.
Boat eletronics
Old 12-05-2010 | 09:35 AM
Default Boat eletronics
Hi!
Iḿ building now a 73" tug and have very much space in the hull.
the electrical question I have are as follow:
Is it possible to use power from main engine battery pack while its charging from a onboard generator? Using a 12V netfeed charger to charge the leadbatteries.
Taking power from a nitroengine running a generator @12V
Thanksfor any help!
Old 12-05-2010 | 10:37 AM
Umi_Ryuzuki's Avatar
Default RE: Boat eletronics
You would need some sort of regulator , but i do know someone that
runs a gas engine in his tug to supply electric power for the boat.
Old 12-05-2010 | 11:44 AM
Like Umi says, with appropriate regulation, no problem.  I would just add that suppression is vital as well.  Telephone systems have been working like this for many, many years.
Old 12-05-2010 | 01:01 PM
Okej, how would a regulator look like or make one?
Old 12-05-2010 | 01:12 PM
Oh my Lord!
Save yourself a whole lot of trouble and use the space for more battery capacity.
You are going to need a lot of ballast anyway.
Old 12-05-2010 | 03:07 PM
Perhaps a regulator that is tyically used in an automobile could be used?
Old 12-05-2010 | 08:43 PM
Ron Olson's Avatar
A boat that big can take a 12-volt deep-cycle battery and run almost all day long. You're going to need the weight for ballast anyway so why not usable weight? I've seen smaller tugs that used one and rode at the waterline so I know that you'd need more weight than what one of those provide.
Old 12-06-2010 | 02:44 AM
Basically, I go along with the bigger battery school of thought, but in the interests of pushing the boundary a bit - what were you thinking of using for a generator?  If it is a mains electricity type (eek!), then a battery charger for your type of battery will do the job.  If it has an auto-mobile type alternator, it might well have the regulator built in.  The normal rules for charging lead acid apply, voltage limiting to avoid over charging, and current limited to the maximum that the battery allows.  It assumes that if the motor wants more than the charger can give, the battery makes up the difference until the demand is removed, when the alternator recharges the battery.
Old 12-07-2010 | 11:33 PM
Banned
so awesome!
