throttle set up outboard
My Feedback: (109)
I know very little about boats-my friend just called and he knows about as much as I do about boats-k&b outboard tunnel hull-the big question"How do you set up a throttle linkage -if we just run a rod out of the back of the boat to carb will result in engine speed changing when turning ? Thanks in advance-jmc
ON, CANADA
RE: throttle set up outboard
The 7.5cc OB thread is currently at the top in the nitro section. Lots more info there. Check that out. You may have to search for the other one, we do have a thread dedicated to the 3.5cc class.
Ryan
Ryan
