i need help
You will probably have to splice the keel due to lack of length but I'd start with 1/4 for that and 1/8 for any cross frames. Your best plywood for boats are 3ply 1/16 for skins, 5 ply in 1/8 and 9 or so in 1/4. I use birch ply with spruce for stringers and glue blocks when I build.
My Feedback: (51)
I used to use aircraft grade plywood in 1/8" for skin and frames and 1/4" for engine rails and transom on gasser boats,but with it's price increase and shipping costs I haven't been building for a while.I used to buy from Aircraft Spruce as you can get 24" x 48" where as the other companies mostly have 12" x 48" and sometimes you can't get too many parts on a piece that size and have waste.I like to get parts laid in really close to each other to avoid excess waste.I've found 1/8" and 1/4" birch 3 ply plywood at a local building center at a good price for a 4'x8' sheet.It's got a nice sanded surface on one side,but would have to be sealed really good.
They also have sheets of a white plywood that one sheets bends width wise and the other sheet bends length wise .This stuff can be bent in a circle.I've tried lauan plywood but it doesn't bend too easily before it starts cracking,plus it splinters on the edges.
For a cargo boat that size, 1/8 for most of the skin, I assume that in your home improvement stores there is a section with small section wood strips - 1/4x1/4 makes good framing and joining reinforcement for corners. My first ones got their raw material from the panels of a dead kitchen door.
