Need help with parts.
Hello there, I'm fairly new to to the boat building. And I need help to see if the parts I will buy are going to work together.
Its simple and not that many parts. But I need to be sure first. thank you alot
1. Propeller
2 Motor
3 Transmitter 49mhz
4. Battery and charger
5. servo
6. propeller shaft
Reciver 49mhz
1. Propeller
2 Motor
3 Transmitter 49mhz
5. servo
6. propeller shaft
Reciver 49mhz
If they are all spares for the same boat, probably yes.
49MHz is not a common model use frequency, in my bit of the world reserved for RTR toys. Check your local regulations, as radio frequency use laws vary worldwide..
Are you trying to make the same size and performance boat as the one that your spares were intended for?
